Coolant replacement.
Old 01-05-2012, 04:16 PM
Zagohhr's Avatar
Hi there.
I had the issue of the gurgling noise everytime on the morning when I turned on my HHR. The cause was low coolant level. I just added green coolant (In México the only place where you can buy DEX COOL Coolant is the dealer, and costs 45 USD per Gallon ) and follow the procedure to remove the air from the system. I traveled to the US border and bought two gallon jugs of prestone Dex cool (not dilluited). Then, considering that I added about 1 quart of green stuff and that my HHR has 5 years, it´s time to change the coolant. I saw that there is a petc**k near to the radiator and I assume that this is the draining hole. Now, I have these questions:
1. All the coolant will be drained from the system just opening the petc**k? I don´t know if it´s like when you replace the tranny fluid, that there´s is some stored that you can´t drain.
2. May I flush just with plain water, or I need to add any flush liquid?
I will apreciate your comments!
Zagohhr is offline
Old 01-05-2012, 04:31 PM
Dracos's Avatar
I've been away from car maintenance for a while, but back when I had my Achieva (late 90s), I learned that you can add green to orange, but never add orange to green.
Dexcool is a more efficient coolant, if what I learned long ago still applies, you probably want to get a complete flush and fill back up with dexcool just to be safe. Maybe someone can update me on this...
Dracos is offline
Old 01-08-2012, 04:44 PM
hhrfreek's Avatar
You won't be able to drain it all. The block/pump will retain some coolant, but it is less than a quart. I don't think you need to do a complete flush unless it will put your mind at ease.
hhrfreek is offline
seren89
2.2L Performance Tech
02-02-2015 12:03 AM
babeba67
03-14-2014 03:17 PM
Cheko0602
11-30-2013 10:49 AM
fastsuv
Maintenance and Upkeep
17
10-21-2013 08:15 PM
plumb34
07-06-2010 12:53 AM
Quick Reply: Coolant replacement.
