Panel, front door pops when the rear is open
Hey guys,
I think this is the right forum for this.
I have a 2011 panel and if you pop open the drivers rear door, get out, and close the front door it makes a loud popping sound like metal to metal. I don't see any damage, if you open the rear just a bit more nothing happens.
Just wondering if anyone has run into this.
Thanks.
Thanks.
I don't see any damage, paint peeling, dents, etc.. The gap looks even all the way around. It seems like the rear edge of the front door hits the lip of the front edge, rear door. But like I said not seeing damage yet, its just annoying and sounds painful
sounds like a damaged hinge to me..does the door "drop" atall when it opens??open the door and grab it by the bottom corner..see if u have any up and down movement..dont lift hard..just wiggle it..see if the hinge moves..that popping sound is very common when having a damaged hinge..
There is no noticeable movement in either door. There does seem to be some discoloration at the point where the two doors are the closest when open/closing. Hard to describe, not the bright white as the rest of the door.
Mine does it too. Point of contact on front door has chipped a bit, no big thing. I've had problems with the front door losing a good seal for a long time now...nothing seems to help, so I'm waiting for the door to sag enough to warrant replacing the hinge itself. I'm sure that this is what's wrong in both cases.
Mrs. DLVRNIT
27
11-30-2011 04:32 PM
Telemicus
10
04-13-2010 08:17 AM
