T/C Light & Hard Shifting
Old 12-25-2014, 05:30 PM
lafinests213's Avatar
Did you solve the issue i have a 2006 2.4 with 62000 mile and I'm getting the TC light and hard shifting but no engine light would swapping out the solenoid help and eliminate this issue
lafinests213 is offline
Old 12-25-2014, 06:21 PM
Technical Moderator
Gee, this topic has never been covered.
Check your coolant level and temp first. Then type "hard shifting" into the search box.
That should keep you reading for a couple of hours.
donbrew is offline
Old 12-25-2014, 06:28 PM
lafinests213. You've been on this site long enough to know.
First thing to do is have the codes read. CEL showing or not, you could still have a trouble code stored in the computer.
Fwiw. There are 2 solenoids, not 1 as your post indicates. No sense in just throwing parts at it without a little diagnostics.
firemangeorge is offline
Old 12-25-2014, 07:19 PM
Split the first post and subsequent replies off from a very stale thread.
843de is offline
iblue
06-11-2017 09:46 AM
AMG101080
10-22-2014 05:35 PM
50%buffalo
06-14-2014 06:16 PM
sunset
08-28-2013 08:53 AM
Violet_HHR
09-07-2012 09:25 PM
Quick Reply: T/C Light & Hard Shifting
