Non abs wheel hub and bearing on hhr with abs
Old 09-11-2022, 12:45 PM
Chief771's Avatar
I will be changing the wheel bearings on a 2008 hhr. Can I use a non abs assembly on an hhr with abs. Non abs is half the price and the owner doesn't have much for cash.
Thank you in advance!
Chief771 is offline
Old 09-11-2022, 02:00 PM
Technical Moderator
Sure, if you don't mind the the ESC tossing the car all over the place and The ABS doing strange things. In short, disregarding legal liability issues NO!
You must be shopping at a different place than I do. On Ebay and Amazon w/ABS runs around $50 each. Of course, if you are buying from big box stores expect around $200 each (prove to there is a difference). Hard to find non-ABS.
donbrew is online now
Old 09-11-2022, 09:17 PM
greg8453's Avatar
I wouldn't touch it. If he gets killed or someone else and they find you compromised the vehicle you will be held responsible.
greg8453 is offline
Old 09-12-2022, 12:24 AM
Chief771's Avatar
As it turns out...
The hhr does not have abs brakes. I got a hub and bearing at oreily,s for 80 bucks. Repair complete with no stupid shortcuts. Thank you all for the comments.
Chief771 is offline
Old 09-12-2022, 06:42 AM
Good , thank you for the follow up.
Oldblue is offline
Old 09-12-2022, 09:32 AM
greg8453's Avatar
So it never had ABS?
greg8453 is offline
Old 09-12-2022, 10:54 AM
Right. Case closed.
Oldblue is offline
Old 09-12-2022, 05:01 PM
Technical Moderator
Never heard of a 2008 without ABS.
Old 09-12-2022, 06:07 PM
Well now we have . It’s possibly an early build.
Oldblue is offline
questionMARK
10-21-2016 02:27 PM
slanwar
09-18-2016 10:37 AM
mcgrosjr
Drivetrain (Excluding Engine)
04-24-2013 11:44 AM
rjdelapp
07-26-2012 10:56 AM
helhedded
03-22-2012 06:55 AM
Quick Reply: Non abs wheel hub and bearing on hhr with abs
