Gasoline overflow/vent tube
Old 08-13-2012, 10:39 AM
matt2006hhr's Avatar
When I fill the tank at a reasonable speed, the gas overflow/vent tube overflows. I took the wheel well cover off and pumped to find it spewing from there. In order to keep all of the gasoline that I pump, I have to pump slowly and intermittently. I took the filler neck tube off. It has no obstructions. There is some type of box that connects to the back of the has tank that also connects to the vent tube. It appears to have some sort of solenoid between it and the vent tube. Does anyone know what this box is and if out may be the problem? I presented this to the chevy dealership without paying them to look at it. They say they've never heard of that before.
matt2006hhr is offline
Old 08-13-2012, 10:55 AM
SpaceCowboy's Avatar
that should be the canister...sounds like your vent tube is working well
SpaceCowboy is offline
hurst2001
02-19-2013 06:32 PM
working on it
08-09-2011 08:46 AM
Ramos
04-17-2011 06:54 AM
Ramos
10-23-2009 07:45 AM
karen1953
12-14-2007 05:51 AM
Quick Reply: Gasoline overflow/vent tube
