timing chain replacement
HI,
I am getting set to do a timing chain replacement on my 2006 hhr 2.4.
403,000km or just a bit over 250,000miles. Can this be done with the engine in the car or do I have to pull the motor. I do have a 2 post lift in the garage so either is possible but I prefer not to pull the motor unless I have to do more such as crank bearings.(hoping not to go that deep as its not burning a drop of oil yet between changes.
Has anyone ever heard of having to change the balance shaft chain, or do you think its safe to leave as is.
Thanks
Dale
Thanks
Dale
This is from a Cobalt site and maybe some help to you. http://www.yourcobalt.com/forums/ins...ing-chain.html
You don't have to drop the engine but you need to lower it. Which it does make the job harder if you leave it in just because the lack of room. Change all changes and guides and etc . Do it right the first time!
Takes care
Takes care
HI,
Thanks
Dale
Thanks
Dale
Still have not done it. But I just picked up a replacement motor to swap in soon as I get a chance. Picked up a 2.4 le5 from another 2006 with 65,000 km or 40k miles for $400. Should get me and the car well up past 500,000 km or 600,000.
Dale
Dale
prod
"How To" Tutorial Library
164
07-12-2018 08:20 PM
