Traction Control Off
Old 04-25-2010, 07:23 PM
andoll83's Avatar
Hello All---
This happens every few days:
I'm pulling out of a traffic light, and if I hesitate a little and let up in the gas just a bit, and the traction control off light comes on, and it shifts very hard. I have to turn the car off and back on again to get the light to go back off. What could be causing this? Could I be letting up in the gas between gears or something?
Thanks!
Andy
andoll83 is offline
Old 04-25-2010, 07:34 PM
jay loukakis's Avatar
Thumbs up
Originally Posted by andoll83
hello all---
this happens every few days:
I'm pulling out of a traffic light, and if i hesitate a little and let up in the gas just a bit, and the traction control off light comes on, and it shifts very hard. I have to turn the car off and back on again to get the light to go back off. What could be causing this? Could i be letting up in the gas between gears or something?
Thanks!
Andy
a lot of people have had this problum there is a thread on this over 3879 people have looked at this thread look at 2,4 performance, a good infor on those 2 trouble codes, i changed the intake and the xhast acthators solved my problum, good luck.
jay loukakis is offline
Old 04-25-2010, 10:42 PM
saxrocks2009's Avatar
my dad was mentioning something about that today.. Its something with the 2009's. I dont know if it effects 2008's tho
saxrocks2009 is offline
Old 04-26-2010, 08:00 AM
the 2006 and 2007 have the most problums with auto and the 2.4 engines, check the forum I mentioned.
Old 04-27-2010, 06:25 PM
andoll83's Avatar
do you have a link to the thread? didn't see it when I looked at the forum
andoll83 is offline
Old 04-27-2010, 08:13 PM
do you have a link to the thread? Didn't see it when i looked at the forum
look at 2.4 performance coded po10 and po11
Old 04-27-2010, 08:33 PM
I looked they have deleted it. If you check for codes, po10 and po11 the tc light come on but it is not the traction control that light comes on for many codes, if you grt those 2 codes it needs to replace the 2 cam solenoids for both the intake and the exhaust. Patr numbers intake #1262834, exhaust #12628347 i paid about $110.00 for both solved my problem and many other people, remove the air cleaner the 2 are on the left end of the engine takes a 10mm ****et very easy to do maybe a half hour to do both fixed my problum did this about 3 weeks ago good luck, they control the variable valve timing, i had over 20,000 misfires if you have the factory manual they control a lot of other things.
Old 04-28-2010, 11:41 AM
geg
geg's Avatar
Do you have a picture of the "service manual"? If there is - please let her. Better to see once than hear a hundred times.
geg is offline
Old 04-28-2010, 12:16 PM
Here is a documented procedure(WITH PICTURES) for replacing those solenoids: https://www.chevyhhr.net/forums/how-tutorial-library-21/camshaft-position-actuator-solenoid-valve-replacement-w-pics-p0010-11-p0013-14-a-28779/ - as mentioned previously, it is a pretty easy job and takes 45 minutes max.. The parts in Canada from a GM dealer were $75 for eash solenoid.
whopper is offline
Old 04-28-2010, 04:50 PM
whopper im glad you responded as they deleted the orignal thread, many thanks to you as it solved my problum and I hope for many others again my thanks, it is too bad Chevy did not publish your report, my chevy dealer just walked away. hope you have a great day again thanks.
Quick Reply: Traction Control Off
