Warm A/C no readout on temperature gauge
Old 07-30-2012, 02:57 AM
HHR911's Avatar
I turned on my A/C and it blew warm air. I drove around for a bit thinking that maybe it will just kick on but no luck. In addition, when I took a look at my gauge cluster, the needle on my temperature gauge didn't even budge (read zero degrees even while I was driving around). When I looked at the digital display figuring that maybe the temp gauge went bad, there were three dashes followed by the Farenheit symbol (---F). I have no temperature readout and my A/C is blowing warm air. Any thoughts?
--HHR911
2006 HHR 2LT 5spd manual 63000miles
HHR911 is offline
Old 07-30-2012, 04:40 AM
Most likely a bad thermostat. It won't allow the AC to engage. Has been a common problem for the HHR.
firemangeorge is offline
Old 07-30-2012, 05:43 AM
jeff schaffer's Avatar
Also look into the Freon that is the only part i had to fix on my hhr
I had a problem with it had a leak in the tube
jeff schaffer is offline
Old 07-30-2012, 08:37 AM
LawDog88's Avatar
As fireman said it could be the t-stat. It could also be as I just found out recently, an "ambient temperature sensor" as I've been through 3 t-stats and the condition persisted. So now they are trying that. If you take your HHR to Advance Auto. You can pull the code and erase it to allow use of the A/C again. It may be temporary depending. So please don't expect it to continue working 100% until you have it fixed.
LawDog88 is offline
Old 07-30-2012, 11:17 AM
Thermostat.
whopper is offline
Old 07-30-2012, 01:44 PM
JoeR's Avatar
Originally Posted by whopper
Thermostat.
What about your thermostat, whopper??
Hey, I do agree!!
JoeR is offline
Old 07-30-2012, 02:20 PM
ChevyMgr's Avatar
I've heard that a thermostat will cause this. Not sure where I heard that.
ChevyMgr is offline
Old 07-30-2012, 03:09 PM
JoeR's Avatar
Brad, you being old and senile.... on da interwebz!!
JoeR is offline
Old 07-31-2012, 10:29 AM
Oh sorry - just practicing my typing skills.
whopper is offline
Old 08-02-2012, 08:48 AM
Try using the Search function at the top of the page and look for thermostat. This is a well documented issue here, and a semi common problem. Without going into a long description, when the thermostat jams open due to a deteriorated gasket on the thermostat itself, the engine is slow to warm up, and an undertemperture condition is raised, blanking out the digital temp display, disables the a/c at the same time, and sometimes will throw a code and light up the CEL.
It's the thermostat.
whopper is offline
Quick Reply: Warm A/C no readout on temperature gauge
