Wheel bearing issue?
Old 01-31-2012, 07:10 AM
anthony303's Avatar
I just replaced my pass side frt wheel hub bearing sunday, bought the better on raybestos pro series 3 yr warranty anyway noise is gone so it fixed problem. Developed another problem, abs light is on and tc light is on,i suspect its the connection harness im i correct or is the bearing abs pigtail bad? Any advise, wife says car drives fine no issues no noises? Oh its a 2007 hhr lt with obviously abs
anthony303 is offline
Old 01-31-2012, 07:23 AM
oneton's Avatar
I would try having code cleared and road test to see if it returns.
oneton is offline
Old 01-31-2012, 07:25 AM
dr_fosg8's Avatar
I would guess that something did not get reinstalled correctly with the wheel speed sensor on the side you worked on.
dr_fosg8 is offline
Old 01-31-2012, 07:31 AM
dr_fosg8's Avatar
According to this thread I found, https://www.chevyhhr.net/forums/show...l+speed+sensor
The ABS sensor and pickup ring is part of the hub assembly. Perhaps the parts place gave you the part for a non ABS HHR.
dr_fosg8 is offline
Old 01-31-2012, 07:39 AM
anthony303's Avatar
well i bought it at rock auto with abs, removed sensor ring and reinstalled it and plugged harness in, know harness goes through spindle and i pulled it through i guess i gotta look at it tonight....
Old 01-31-2012, 08:00 AM
Did you by chance turn the key to the "on" position while you had the hub taken apart. If the sensor was unplugged at that point,it could have stored a code. Not for sure on this,but trying to throw out another possibility.
firemangeorge is offline
Old 01-31-2012, 09:42 AM
barfan1's Avatar
If you disassembled the sensor ring on the hub at anytime, you have damaged the speed sensor and the sensor will continue to throw codes. See if you can get rockauto to warranty it out and when you install the new one make sure you do not take apart the sensor ring. The correct Raybestos part for HHR with ABS is 713206, this should be the OEM hub assembly as Raybestos(Affinia) buys from KBI(GM OEM Hub supplier).
barfan1 is offline
Old 01-31-2012, 05:22 PM
Technical Moderator
You mean you removed the sensor ring from the NEW bearing and re installed it? If so, why? That probably destroyed the thing. If you mean you had to remove the sensor ring from the OLD hub the install it on the NEW hub, then you got the wrong hub.
Or, did you mean you just unplugged the old hub, the plugged the new one in? Then check the plugging in job, and the key on when the hub was disconnected makes sense too.
RockAuto has a confusing way of listing the hubs.
donbrew is offline
Old 02-02-2012, 12:20 PM
anthony303's Avatar
great news rock auto warrantied new one and got timkin replacement and all lights off and car is back to norm thanks guys for the info.....
josephdstone
06-07-2016 10:30 PM
fastsuv
12-03-2014 10:38 AM
Twistedtat
08-05-2014 05:58 PM
Silverfox
Maintenance and Upkeep
10
12-18-2012 12:17 PM
jefflund
Drivetrain (Excluding Engine)
08-03-2012 07:26 AM
Quick Reply: Wheel bearing issue?
