Wipers making squealing noise
Old 04-23-2014, 05:57 PM
simonb's Avatar
Hello all,
I noticed today that my wipers are a little slower and are squealing. Wondering if this means my linkage needs to be replaced or if its just a part I can grease/change.
simonb is offline
Old 04-23-2014, 07:29 PM
Before assuming the worst, check the blades first. Worn out blades will squeak and create extra drag, you might get lucky and find that your problems can be traced to a couple strips of knackered rubber.
843de is offline
Old 04-23-2014, 07:57 PM
X2 !!
Oldblue is offline
Old 04-24-2014, 01:23 AM
..... and if you find that the blades are ok, here is a link to a How-To article on how to replace the wiper motor and how to take the wipers and cowl off to check the linkage for the wipers: https://www.chevyhhr.net/forums/how-tutorial-library-21/how-fix-wiper-transmission-32975/ (pictures are partway down the thread of the linkage, so scroll a page or two).
whopper is offline
Old 04-27-2014, 07:58 PM
Don06's Avatar
Get a glass polishing kit to clean all the wax off the window, clean it with alcohol then apply Rain-X or similar product and you won't need wipers.
Don06 is offline
bobiroc
07-18-2012 11:39 AM
snoopyspaz
55
08-22-2011 05:45 PM
meeks22
04-18-2011 07:25 PM
asanti
08-06-2010 05:22 PM
geekdad
04-17-2007 12:45 PM
Quick Reply: Wipers making squealing noise
