The Green Land-Speed Machine
I actually used the chute on the 136 mph run--didn't need to, but I wanted to get used to the hit. It's a land-speed chute, which has a ribbon-style canopy and is about twice as long as a drag chute. Worked like a charm...
Most people with LNF's have had good luck with E85 and adding a 5th injector in the intake. You can get most of the details on the HPTuners site. That 360 was that at the wheels or the flywheel? BTW you wouldn't hear it knock, the computer would detect and adjust the timing. Log the next run you make, it will show and tell you everything that's going on. Has anything else been done to the motor?
Hey, thanks! It's definitely different, and the car gets a good amount of attention in the staging lanes. But that's also the great thing about land-speed racing--you get just about every vehicle you can imagine out there, and everyone's cool with it, no matter how weird it might be...
That's what I'm hoping...the driver just needs to get better!
The HHR suddenly remembers its a flying brick when you let off at that speed and slows down well on its own.
They DO slow down pretty well by themselves. The only problem at Ohio is that there are two turnoffs--one about 1/4 mile after the traps and the other at the end of the runway, about 1/2 mile from the traps--and if you're in a slow car (i.e., me), they get annoyed if you don't take the first turnoff...
Cool project!!
Does this bolt right in (to the engine, and does the shifter line up in the floor openning?), and how are the ratio's compared to the SS 5-speed, if you know? Also, is it rated for more power?
Also, about stopping in a 1/4 mile: are you required to have 4 brakes on the car (thinking about weight reduction), and have you thought about adding better pads in the front/rear? Also what tire size(s) (width) are you using? Do you think the shute was needed?
Good luck in Maine!
Good luck in Maine!
[QUOTE=NoGrip61;783518]Cool project!!
QUOTE]
They sell conversion kits on ZZP for them. Fairly pricey, but I believe they are a little more stout than our F35's. And from what I've seen, 6th on the F40 is about the same as 5th on the F35, but with closer ratios.
QUOTE]
Gary Perkinson
Racing Discussion
04-30-2013 07:41 AM
