How to replace headlight bulbs on 2007 HHR?
Old 10-21-2013, 11:25 AM
SlickRick2's Avatar
Originally Posted by geg
great video. visual process.
I watched with pleasure. Recommend.
http://www.youtube.com/watch?v=ldlJdh3M8fs
Thanks for the video, Greg; it was a big help. I replaced the driver's side, turned the wheel all the way in. Besides the two plugs, I took out the upper 7mm bolt which let the wheel well come back a little more. I ordered the H13/9008 bulb online (Advance Autoparts) and picked it up at the store down the road. This gets you an extra 20% off, so the bulb was $12.83 with NJ tax.
SlickRick2 is offline
Old 10-29-2013, 08:27 AM
a76marine's Avatar
I also used this thread and Geg's video to replace my headlights last night. Start to finish took about an hour but this was in the dark with a flashlight, needle nose pliers and a 7mm socket.
Love the HHR community, made it as painless as could be and saved me $70 or so by not having the dealer install the lights. :)
a76marine is offline
Old 01-05-2016, 06:51 PM
Rolly's Avatar
Smile Where to find some push pine
Hi i need to replace my headlamps and i will have to do the work out side and it cold here so i am sure the push pine will brake so i did go to UAP Napa to get my 9008 headlamps and i did ask for some replacement push pine but the have a lot of model .
So any one in the site no the model of the push pine i need on my HHR 2007 LT.
Thank for your support
Rolly is offline
Old 01-05-2016, 08:58 PM
Just pull one of your existing pins out and match it up with what Napa has in stock. The pins are pretty strong, and shouldn't break unless they have been removed/installed many times.
Old 01-06-2016, 08:18 AM
Rolly , welcome to the site!
The first time I replaced my headlight bulbs, I pulled the pull pins then changed the bulbs, put the screws back in.
I took a sample push pin to my local parts palace, like NAPA and got four new ones then pushed them into place .
Old 01-06-2016, 08:40 AM
NAPA has a book full of samples so you match them up.
Old 01-09-2016, 01:17 PM
ImNewHere's Avatar
I replaced mine with LED headlights since I was tired of replacing them every 10-12 months.
ImNewHere is offline
Old 01-17-2016, 04:43 PM
jimfet's Avatar
I just replaced both of mine two weeks ago. Can you believe they both went out at the same time. Went to unlock the car with my fob and no lights flashed. After checking, I had a high beam on the passenger side. They were working the day before. Being it happened like that, I thought it was a fuse, but they were fine. Put in two new bulbs and wah lah. I almost fainted when I paid $50 a pair at Advance. I also bought the tool to remove the fasteners.
jimfet is offline
Old 01-18-2016, 12:35 PM
SlickRick2's Avatar
Is there more than just a different type bulb when you replace with LED's? Anthing extra to do?
Old 02-06-2017, 04:28 PM
boost8d's Avatar
Originally Posted by VinceP
I just replaced both of mine on my 08. This is pretty much how it is done. I had a little trouble getting the new bulb to seat back in. I discovered that when I took the old bulb out the sealing gasket at the base of the bulb stuck to the back of the headlight housing. After I discovered this and pulled it off the new one went right in.
Not that difficult.
Glad I checked this site for this. I was struggling to get the new bulb in, saw this and sure enough the old gasket was still there. Once I got that out of the the way the new bulb went right in. Was able to do the other side in about 5 minutes, gasket was stuck there too.
boost8d is offline
Wifes07LT
Mods - Exterior
10
11-08-2014 10:12 PM
Frenchy42
01-27-2014 09:13 PM
andoll83
11-24-2008 10:48 PM
m0rie
07-12-2008 09:14 AM
laylowcustoms
03-02-2008 08:38 AM
Quick Reply: How to replace headlight bulbs on 2007 HHR?
