Hub assembly vs. Wheel bearing
Old 10-28-2011, 06:09 AM
  #31
barfan1's Avatar
The axle nut that is used on the HHR has been used on many GM cars over the years, you can get it at parts stores for around $5.00 bucks at O'Reilly's. It is the same nut as the 82-05 Cavalier/SunBird axle nut. MTM part#05170 and Dorman Part#615-089. Don't go to the dealer or Advanced, the prices are way jacked up.
barfan1 is offline
Old 10-28-2011, 09:35 AM
  #32
db/sb's Avatar
Yeah, it's a fairly generic M20-1.5 axle nut. Fits a lot of different Ford, GM, and, IIRC, Mazda or Toyota. Even less than $5 at some stores.
db/sb is offline
Old 10-28-2011, 06:53 PM
  #33
At Advance etc. it lists for around $30 ea., but now I know better!
Old 02-05-2014, 02:37 PM
  #34
bargabus's Avatar
The plus is the hub assembly is everything. I replaced mine 8 months ago. Recvently, there were warning lights telling me to service traction, EBV, etc. It turns out there is a gererated signal that comes off each wheel to tell the CPU that you are slipping. The generator ring was bad. The hub fixed all. Weeee!. Hope it lasts for a while.
bargabus is offline
Old 09-28-2014, 11:14 PM
  #35
canroc's Avatar
Anyone know the size of the axle nut for a 2009 SS? Going to replace the wheel hub assembly of the two front wheels. I'll need to get the proper deep socket.
Thanks.
canroc is offline
Old 09-29-2014, 09:40 PM
  #36
canroc's Avatar
Thanks.
Turns out it is 36 mm.
canroc is offline
Old 04-22-2016, 01:17 PM
  #37
esmarkey's Avatar
Can anyone confirm this for an SS? I have heard all different sizes. Borrowed a set to do mine last time, but forgot what size it was!
Socket to remove wheel nut on an SS + 36mm DEEPWELL ???
esmarkey is offline
Old 04-22-2016, 02:10 PM
  #38
The wheel nuts are 3/4 or 18 mm, the axle nut on an SS is 35mm
Last edited by Oldblue; 04-25-2016 at 02:38 PM. Reason: Corrected the size for axle nut socket
Old 04-25-2016, 02:03 PM
  #39
esmarkey's Avatar
Guys, I replaced the wheel bearing assembly and it did solve the Christmas tree (lights everywhere) I had going on.
I did end up buying the correct socket for the axle nut, and it is 35mm, NOT 36mm! I was borrowing a set of metric deep well sockets and the standard 35mm fits, but is a real bear to get the nut out of the socket as it fits VERY tight. I bought the "axle nut socket" in 35mm and it has reliefs cut at the points (for lack of better explanation) and is MUCH easier to get the nut out of.
esmarkey is offline
Old 04-25-2016, 02:39 PM
  #40
So a standard 36 mm deep socket was to big?
Quick Reply: Hub assembly vs. Wheel bearing
