Blue- Good luck on a new walk behind mower. New to many are not what the old ones are... Still running my 2006 Briggs Flathead, (wife is main operator) it has been super since we bought it new..
For our bigger parts, my Zero Turn is super.
PS: Had the HHR out running to get my gas cans filled with 100% gas for mowers. My HHR likes it too.
Thanks, I’ll try and make the new mower last 36 years , by then I’ll be 106 years old.
Today the HHR is parked, waiting for appointment to have that broken bolt removed on Thursday morning
Today, I changed out the exhaust VVT solenoid/actuator (12679100) since I changed the intake one a couple weeks ago. Let's see if that stops the minor oil leak I discovered. Also, I replaced the rear hatch lift supports. Thank you again, RockAuto!
2011 LS coolant temp was getting a little erratic, so she got an overdue coolant dump and a new thermostat (The Mahle I had in stock. Don't start, you guys.) Much better now. VERY stable at 180 in cool weather. Excursions in rhe range of 178-181. I suspect there is no 179 because I've never seen it.
We'll see what Summer brings.
Also finally got the new #2 O2 sensor in. No more P0138 & nuisance CEL. Yet.
