Tire Pressure Monitoring FAQ's
Old 01-03-2014, 08:07 AM
  #71
Originally Posted by finnhhr
ordered ac delcos, funny thing- came from states but country of origin is UK; great Britain... must be same in use on some opels and vauxhalls?
Yes. And Saab, etc.
Old 02-22-2018, 08:15 AM
  #72
David Mack's Avatar
Two sets of wheels
I have a set of steel rims with studded winter tires and the original tire pressure sensors are mounted into this set. I also have a set of alloy rims with summer tires and no sensors. Can I get a second set of sensors and teach them and somehow switch between the two sets easily?
David Mack is offline
Old 02-22-2018, 08:51 AM
  #73
greendot's Avatar
Yes, you can. I have an inexpensive tool that I use because of many different cars, but a friend used to do it on his SS with a procedure that is in the owner's manual.
greendot is offline
  #74
Welcome.
Yes - just swap between sets and re-sync the sensors as per the info in your owners manual.
Old 02-22-2018, 10:14 AM
  #75
Originally Posted by whopper
Welcome.
That is if it is not a 2010-2011 model. They need a special tool.
Also, be sure to store the out of service wheels out of radio range of the car.
Old 02-22-2018, 07:15 PM
  #76
His spec sheet says he's got a 2009, so he should be ok. Good point about keeping the spares away from the car - that's screwed up a few people over the years.
Old 05-15-2018, 05:06 AM
  #77
User Omega's Avatar
They make what they call "cloneable" sensors now. You can buy a set of them to stick into your second set of wheels. Then when you swap there is no need to reprogram. There will be the initial need to clone the new sensors though. Most tire stores can do this for you.
I use them when swapping from my street tires to track tires on another car.
User Omega is offline
Old 05-21-2018, 07:06 PM
  #78
Blue_SS's Avatar
Cool deal!
But, you use TPM on track tires??? I never worried about it.
Snow tires are the killer app for this...
Blue_SS is offline
Old 05-24-2018, 02:40 AM
  #79
User Omega's Avatar
Originally Posted by Blue_SS
Cool deal!
Yes, lights annoy me and if I lose tire pressure, that car will be on the frame.
Old 08-21-2018, 02:43 PM
  #80
LDelco's Avatar
I have been looking at a set of new wheels for my 2008 HHR LS I really want the
Wheel Vintiques 08-Series Smoothie Wheel Size: 16" x 6-1/2"
Part Number: 939-08-6621105
They look Great with the matching Baby Moon hub caps. In the information tab, it says the wheels are Not TPMS compatable. has anyone used these wheels? If so how did you get around the TPMS problem. I have seen these, or wheels that look like these wheels on an HHR, and they look great.
LDelco is offline
Quick Reply: Tire Pressure Monitoring FAQ's
