Camshaft pos actuator
yes you can repair yourself.. Be careful, there are sensors & solenoids for IN & EX.
Give these links a read first, before you spend money...
https://www.chevyhhr.net/forums/how-tutorial-library-21/camshaft-position-actuator-solenoid-valve-replacement-w-pics-p0010-11-p0013-14-a-28779/
https://www.chevyhhr.net/forums/problems-service-repairs-42/both-cam-sensors-changed-still-throwing-p0010-code-44419/
Intake CMP solenoid is the front one.. on pass side. Gotta remove air filter housing for easy access..
....and the plugs are slightly different, so there is no way to mix them up when re-attaching.
Got mine on e-bay from a Chevy dealer in Florida. e-bay name is number1gmparts
$39.99 each for the actuators. And yes, the parts are factory GM in original boxes.
By the way the new part numbers are 12655420 and 12655421. I bought mine at the dealer for $52 each, could have gotten them for $39 each online but choose not to wait for the $20 diff and just ran to the dealer.
