Hard Shifting, Traction Control Light and P0010 P0011
Old 11-21-2012, 07:14 PM
  #101
Jimslt2's Avatar
RE ....the part numbers above i went to gm parts direct and those part numbers come up as sprockets ? ? ? Am i doing somthing wrong ? ? ?
Jimslt2 is offline
Old 11-21-2012, 07:26 PM
  #102
No, they come up as "valves", not "sprockets" - and it looks like the parts have been updated yet again, as noted on their parts page.
Old 11-21-2012, 07:53 PM
  #103
Jimslt2's Avatar
i apologize the category is Engine Camshaft Sprocket .... thank you . i thought i was going nuts LOL
Jimslt2 is offline
Old 11-22-2012, 01:41 PM
  #104
You might want to have a look at this thread - https://www.chevyhhr.net/forums/how-tutorial-library-21/camshaft-position-actuator-solenoid-valve-replacement-w-pics-p0010-11-p0013-14-a-28779/
Make sure you skip to the end for the latest info and updates though.
Old 12-07-2012, 08:31 AM
  #105
Jimslt2's Avatar
thank you for all the help i ordered the parts only took me 20 min to do and no problems since : )
Jimslt2 is offline
Old 06-08-2014, 05:03 PM
  #106
50%buffalo's Avatar
Originally Posted by phill_ward
So the story goes I had the problem and I ordered the parts, from GM parts direct which at the time I didnt know must look at their orders and then take a 5 day lunch cause it took 2 weeks to deliver them, so in my 2 weeks of waiting i decided to make sure all the fuses and relays where seated properly, checked them reseated them and everything and the problem (after i deleted the code) went away for a week and a half. then the parts finally came and the problem was still gone. so I decided to put the parts in even though i didnt have the problem and its been like 2 and a half weeks and no prob...
I checked my fuse box and could not believe 9 relays were not seated properly..is that even possible?
Anyway I would highly recommend checking the fuses
50%buffalo is offline
Old 06-08-2014, 05:05 PM
  #107
50%buffalo's Avatar
You are the best Whopper!!
Old 03-22-2015, 09:01 PM
  #108
MrRiceGuyRJ's Avatar
I have read through this thread and am having a hard time knowing if what I'm experiencing is the same issue. My cars traction control light came on after a 500 mile drive. Once it was on it was shifting hard when putting in and out of the drive, and shifts hard out of first gear. No check engine light, no error codes that I could get. I turn off the car, the next day its running fine, no issues. Drive back home and right around 500 miles the symptoms return. Is this the same intake and exhaust actuator solenoid fix?
MrRiceGuyRJ is offline
Old 03-23-2015, 02:21 AM
  #109
Well, it is a possibility - but without any codes from the CEL, it is impossible to say for certain. Generally the solenoids will light up the CEL with those p0010/11/13/14 codes. There are numerous other conditions that can cause the symptoms you are experiencing.
Off hand I would not suspect the solenoids causing the problems. I'd be leaning more towards one of the ABS sensors in one of the hubs. You can try swinging into an autoparts store such as Autozone to see if they can pull a code (even if the CEL is not lit up) - they will do it for free - but they may not have a reader available that will pull ABS codes. A GM dealer can do it as well, but likely will want a "diagnostic fee".
I'd suggest having the codes read when the TC light is lit. Without positively determining what the cause is via a code, you can just end up throwing parts/$'s at it, and never get it resolved.
FYI: to clear the error light yourself, (and the hard shifting) you can try disconnecting the NEGATIVE post on the battery in the trunk for a few minutes. No promises, but I think it will clear it till the next occurrence is detected.
Hopefully that helps? Let us know the results if you can. Best of luck.
Old 03-23-2015, 04:29 AM
  #110
Which year and engine do you have ? 2.2 or 2.4 ? Early 2.2's did not have the VVT engine so there are no actuator solenoids.
Also, does your car have ABS ?
Quick Reply: Hard Shifting, Traction Control Light and P0010 P0011
