Tire Pressure Sensors
Old 08-28-2008, 08:11 AM
esmarkey's Avatar
kwboydston, just FYI the SS has an all metal stem and the sensors. Maybe you could order those?
esmarkey is offline
Old 08-28-2008, 11:02 AM
wysguy's Avatar
from what I've seen, most "chrome" valve stems are simply chrome bands stuck over a rubber stem. Maybe you could get a set of those from your nearby auto parts store, de-chrome them, and (LIGHTLY!) glue the sleeves on the stems on the vehicle?
wysguy is offline
Old 08-28-2008, 11:39 AM
chevyorange's Avatar
I know. I wrote a long, nasty email to Firestone. I can't believe how shady and terrible their service center felt.
chevyorange is offline
Old 08-28-2008, 07:10 PM
kwboydston's Avatar
I believe I have found some that are all metal, spoke with the folks at Alltire and sounds very possitive
kwboydston is offline
Old 04-01-2011, 08:16 AM
bobiroc's Avatar
Can they be re-programmed by the owner
I know this is an old thread but I was wondering if re-calibrating the sensors can be done without going to the dealer. The weather is warming up by me and I think the snow is behind us so I would like to put my stock RIMs and tires back on but I know that they will not go back where they were taken off from. Just curious if there was a procedure on how to do it yourself.
bobiroc is offline
Old 04-01-2011, 12:26 PM
prod's Avatar
Yep, its in the manual. Manuals are available on the forum here if you dont have one. Its not too hard, but you would want to use a good air compressor.
prod is offline
Old 04-01-2011, 12:28 PM
bobiroc's Avatar
Aw man I have to read the manual
I do not have an air compressor so I may just take it to my dads for that part then.
bobiroc is offline
Old 04-01-2011, 02:05 PM
Gas Man's Avatar
Yeah it's nothing more than putting it into learn mode... then draining each tire starting F.L., F.R.,R.R.,L.R. each time till the horn honks. Read it up... it's easy.
Gas Man is offline
Old 04-01-2011, 02:24 PM
bobiroc's Avatar
Thanks.. I read it in section 5-65 in my manual. I will just put them on at my dads or something and do that method.
Thanks for the info.
bobiroc is offline
Old 04-01-2011, 06:57 PM
useless's Avatar
It is in the manual, fairly simple process after you do it once. If you rotate or swap winter/summer wheels you will have to do it again.
useless is offline
Quick Reply: Tire Pressure Sensors
