Mystery Code: B2AAA
Old 03-16-2012, 12:03 AM
Yeah,please throw up some pics when you can. I haven't been inside one of these engines yet and would like to take a look. Honestly, the word reluctor is a new one for me.Would like to see a picture, so I can get my "mechanical bearings" on this.
(Mike. I KNOW you can find a picture somewhere.)
Old 03-16-2012, 12:45 AM
I can do better than that, how about a tech article on them with pictures!
Click the link below....
http://www.sandyblogs.com/techlink/2...g-wells-1.html
Old 03-16-2012, 07:04 AM
Thanks Mike. Press fit and not keyed. Don't get that design reasoning.
Old 03-16-2012, 07:28 AM
Heritage High Roof's Avatar
Reluctor Inspection
http://i1100.photobucket.com/albums/...1/IMG_5468.jpg
Valve cover after removal of wiring harness
http://i1100.photobucket.com/albums/...1/IMG_5476.jpg
Inside of valve cover after removal
http://i1100.photobucket.com/albums/...1/IMG_5479.jpg
Reluctors can be seen on right side of photo
http://i1100.photobucket.com/albums/...1/IMG_5494.jpg
Cam chain and VVT actuators
http://i1100.photobucket.com/albums/...1/IMG_5491.jpg
http://i1100.photobucket.com/albums/...1/IMG_5482.jpg
Engine with dial indicator set to check exhaust cam reluctor
http://i1100.photobucket.com/albums/...1/IMG_5488.jpg
Exhaust cam reluctor at max valve lift on cylinder #4.
http://i1100.photobucket.com/albums/...1/IMG_5501.jpg
Intake cam reluctor at max valve lift on cylinder #1.
I took more pictures if someone needs to see a specific angle.
Heritage High Roof is offline
Old 03-16-2012, 03:32 PM
I ordered the camshafts today. $200 each from the dealer. I won't get them for a few days because they are only stocked in Lansing Michigan.
Old 03-23-2012, 04:57 PM
Just finished installing the new cams. Checked the reluctors and they are off by about the same amount as the old ones. :-(
Old 03-23-2012, 05:29 PM
Did you get a chance to check the timing mark on the lower chain sprocket?
Old 03-23-2012, 05:53 PM
I did not check the crank sprocket timing mark (that takes an additional 6.5hrs). I held up the chain with the special tools while I pulled the phasers and the camshafts out.
At this point cam timing seems to be irrevelent. The cam lobe to reluctor relationship is off.
I am going to button up the engine tomorrow and see how it runs.
Old 03-24-2012, 11:35 AM
After reassembly it runs the same with the same codes.
Old 03-24-2012, 01:14 PM
Got it - duh me!!!
843DE - what say you laddie? What are the chances the ones fresh from the factory would also be off as well?
Quick Reply: Mystery Code: B2AAA
