Water Leak!
Old 06-28-2010, 07:13 AM
LLH151's Avatar
It is considered a "Maintenence" and it is NOT covered in any warranty from 2006 to 2010. Not covered. Like changing oil, keeping proper pressure in tires, etc. I did contact them too and is what any dealer would tell you.
LLH151 is offline
Old 06-29-2010, 01:29 AM
Well tell that to the memnbers here that had a leak fixed under warranty & one even got all new carpeting too..
Old 07-03-2010, 11:29 PM
B@work's Avatar
I have an 08 without a sunroof and found a jaccuzzi in the driverside floorboard in the front and the back. Drains? please help under warrenty?
B@work is offline
Old 07-03-2010, 11:45 PM
Yes, I would contact your Dealer asap. Do it before it dries up....
Your 3/36 bumper to bumper warranty starts when your ride was first titled.
Old 10-11-2011, 09:12 PM
Black C5's Avatar
Fixed Under Warranty
My wife's New Beetle had a clogged sunroof drain and the dealer replaced the drain line and all the carpets front and rear.
Black C5 is offline
Old 10-11-2011, 11:46 PM
Gotta love warranty
Old 11-12-2011, 06:37 PM
Black C5's Avatar
Sunroof Leak
I had a sunroof leak that turned out to be the drivers side front tube dead-ending in the drivers compartment. It drained directly onto the firewall and down under the carpet. I am still drying the underpad as we speak.
Black C5 is offline
Old 11-12-2011, 06:42 PM
Did you figure out where that tube was supposed to hook up?
Greybeard999 is offline
Old 11-15-2011, 03:16 PM
Black C5's Avatar
Grey:
No. I even had my son (with his good eyes and flexable body) climb under the dash with a flashlight and look for a spot to connect it. He could not find the last part of the drain tube or a hole to stick it in. I spent some time down there before inlisting his help with no success.
I am hoping someone has pics of the left front drain or the installation procedure in written form. I have the manual in PDF form, but can't find the drain replacement discription.
Black C5 is offline
barnie121
10-24-2014 11:55 PM
KyS10
06-19-2013 12:41 PM
pyro panel
10-12-2011 04:53 PM
floridamisfit
07-30-2009 11:29 PM
billbeam
10-06-2008 06:08 PM
Quick Reply: Water Leak!
