Rear lift gate
Old 04-27-2006, 07:30 PM
  #41
scaleguy's Avatar
I checked my gate and all of the lock opertions for that matter todya. I think that the "clunk" is just the actuator resetting, as there is nothing lose rattling etc. in my gate. The lectronics all seem to be in order right now...and I have an exorsist on call in case the electronic demons attack
scaleguy is offline
Old 04-29-2006, 05:03 PM
  #42
Krejaton's Avatar
Yep, I got the clunk from day uno...11/2/05. Not too worried about it but I will have them fix it when I take it in.
Krejaton is offline
Old 04-29-2006, 05:07 PM
  #43
Firewatcher's Avatar
Mine clunks....but nothing is loose. Disney sound effects I guess.
Firewatcher is offline
Old 05-01-2006, 09:52 PM
  #44
Originally Posted by courthousedeb
Took car into dealer yesterday and they told me nothing was loose. They took the gate apart and said that holding onto the button you use to open it was causing it to trip and make the noise. Not sure if they are blowing smoke up my behind or what. They also said that TSB # I gave them was for addressing the problem when the gate wouldn't open...and since mine was working they couldn't do anything. Told them I'd be back when tailgate won't open and would be none too pleased.
I've gone through the ordeal of the rear hatch not functioning, and getting the actuator replaced. Before it malfuctioned there was no clunk of any kind when opening, but afterwards it makes a really loud clunk when opening. If your's is making the "clunk" then I don't think you should worry about it.
jx3 is offline
Old 05-01-2006, 09:54 PM
  #45
wheelsee's Avatar
yeah I played with it last night...and it seems like it's the actuator reseting itself...
-wC
wheelsee is offline
Old 05-04-2006, 06:17 PM
  #46
coolsurf's Avatar
Went to the car, slow at work, and tryed to find the rear liftgate release lever, could not find it. Took a 7" screwdriver, and with the liftgate up I locked the latch. I slid the screwdriver into the slot and pointed towards the lower part of the latch on the driverside. With a little bit of fishing and pushing, was able to unlick the latch. It is not where the book says. It can be done, but take a lot of fishing. You have to angle the screwdriver downwards. Best is to try it with the liftgate open. Good luck!!
coolsurf is offline
Old 05-04-2006, 06:52 PM
  #47
Originally Posted by coolsurf
Went to the car, slow at work, and tryed to find the rear liftgate release lever, could not find it. Best is to try it with the liftgate open.
Um....if it's already open, then why would you need to find the release lever?
jx3 is offline
Old 05-05-2006, 11:22 AM
  #48
coolsurf's Avatar
JX3, it's easer to try it with the liftgate open, that way you can see both sides and watch it work.
coolsurf is offline
Old 05-05-2006, 11:29 AM
  #49
Have you gotten it to work with the door closed?
jx3 is offline
Old 05-05-2006, 11:42 AM
  #50
coolsurf's Avatar
JX3, yes, but a lot harder to find the right spot.
coolsurf is offline
taz3
03-20-2019 09:01 AM
raffmanlt
03-27-2013 06:12 AM
AJochum
09-09-2009 02:51 PM
raps hhr ss
05-22-2008 09:27 PM
chuktaylor2
09-06-2007 11:12 PM
Quick Reply: Rear lift gate
