Keyfob cold solder repair
Old 07-05-2009, 11:53 AM
Wooglin's Avatar
Great Writeup... though I found the thread coincidentally, haha.
I fixed mine last week.
Still, it's nice to know I did it correctly on my own!
Wooglin is offline
Old 07-07-2009, 05:38 AM
Jeff®'s Avatar
Funny (not) the dern thing's been acting up the past week. Put in a battery I had lying around and it gave the low fob battery warning on the DIC.
I put in a brand new one and only the lock button would work. So I had to open it up and clean the contact pads on the PCB with an eraser, and also the conductive button backsides. PITA but it's working again.
I noticed three unused contact pads on the board. I guess trunk release for one, but the other 2???
Jeff® is offline
Old 07-07-2009, 03:39 PM
Sno White's Avatar
My guess would be the Panel HHR side doors.
Sno White is offline
Old 07-17-2009, 10:02 PM
WEB
WEB's Avatar
I had to go through exactly the same thing, but in my case it was due to my carelessness. I hate to admit this, but I left the keyring in my pocket when I ran my clothes through the washer and dryer. It was a real surprise to find it in the dryer after I removed my clothes. Well, I figured, my remote is probably toast, but it's nice and clean. Naturally when I checked to see if it still functioned, it didn't. I decided to open it up and investigate. When I opened it I discovered the battery clip was loose. All three solder connections had come loose. I assumed this was more the result of getting beat up in the dryer, not a design flaw. I got out my soldering iron and reinstalled the battery clip. When I tested the remote it worked perfectly. And did I mention that it was nice and clean.
WEB is offline
Old 07-22-2009, 11:33 AM
wagoneer's Avatar
programming?
If I need a new Key FOB the only way to get it programmed is through the dealer? You can't buy the harness/software and plug it into a laptop? Both of my FOB's are broken and the solder repair didn't work.
wagoneer is offline
Old 07-22-2009, 12:47 PM
Sno White's Avatar
First, check your work. The type of soldering required for this FOB "repair" generally requires a bit of experience.
While it is technically possible to program the vehicle with a laptop and the "right" software instructions and cable, I don't believe anyone has hacked the GM codes and distributed them to the public for this purpose. I would like to hear about it if they have!! I have a lot of things I would like to tweek with this vehicle, but can't.
See:
https://www.chevyhhr.net/forums/show...88&postcount=5
To quote myself, "The FOBs do have to be programmed at the Dealer or a well-equipped Locksmith may be able to handle it. If you are adding a FOB, gather up all your FOBs and take them to the person programming the vehicle. If the programmer makes a mistake or if four or more have ever been programmed to the vehicle, they may need them ALL present."
Old 08-08-2009, 02:16 PM
xzombiex66's Avatar
well looks like I am having this problem it happened to my first fob about a year ago so i just switched to my other one now this one is broke. I have 2000 miles left on my warranty looks like im heading there Monday.Is there a service bulletin out for this?
xzombiex66 is offline
Old 08-08-2009, 09:21 PM
damronjr's Avatar
Found the same problem with mine, didn't even realize it was a recurring issue on the forum! Mine quit working so I popped it open to find the battery clip loose and off the points, pushed it back on, only to find it had later come off again. This time I used some super glue to hold it on.
damronjr is offline
Old 08-27-2009, 03:30 PM
wagoneer's Avatar
Well I need some experience soldering because I killed my two fob's. So I bought three on ebay and two of them had detached cages. Anybody know where can I find someone who can do this or teach me how to do it?
The good news is the programmer at the dealership did the programming for a case of Bud Lite!
wagoneer is offline
Old 08-27-2009, 11:11 PM
WEB
WEB's Avatar
Surely you must have a friend who dabbles in electronics who can resolder the battery holders. It's not a difficult task for someone with some soldering experience. If you can't find anyone else to do it I'd be happy to do it for you, but you're in Florida and I'm in Ohio. You'd have to send them to me, and trust that I'd send them back to you. Since I'm not well known here if you're not interested I'll understand.
WEB is offline
Quick Reply: Keyfob cold solder repair
