Rear drum brake repair tutorial
Old 03-12-2014, 04:46 PM
I finally triumphed by inserting a prybar between the drum and backing plate while beating on the drum with the "bigger hammer". Be careful though, there is another bit of metal on the backing plate that you may get caught on.
Old 03-12-2014, 05:45 PM
pjohnmiller's Avatar
Originally Posted by Lucky
If the drums wiggle on the the hubs then you may be stuck on the brake shoes. You may have to back the adjusters off to get the drums off.
drums do not seem to have any wiggle..I think they are stuck on axle..thanks
pjohnmiller is offline
Old 03-12-2014, 05:47 PM
If the drum is stuck at the hub, there will be no movement there when trying to take off the drum.
If only the shoes are holding it, there will be a little give and you should be able to see the hub is free.
Over the years I've had to use a BFM(Big Frigging rubber Mallet) on many different types of drums. It's not just a HHR thing.
Chevy_dork04
Mods - Exterior
08-23-2017 04:42 PM
toolman101
11-15-2014 06:44 PM
RustyNCA
Maintenance and Upkeep
13
04-26-2014 02:25 PM
Quick Reply: Rear drum brake repair tutorial
