Round jack points for a floor jack
Old 03-29-2009, 08:25 PM
masterchief1112's Avatar
jack point just behind it. on my rockers there is an arrow that points under the car to it.
masterchief1112 is offline
Old 05-29-2010, 11:45 PM
Good info..
Old 06-16-2011, 10:23 PM
Silverfox's Avatar
Originally Posted by ChevyMgr
Without a lift ,GM does not want you to raise both sides of the front end at the same time is my guess. But you could lift one side, place a jack stand under it and then lift the other side.
I think that picture is the United Kingdom version. You know how the have everything on the wrong side over there.
I don't think it is a United Kingdome Version. Good guess though ..
It's just looking at the frame from the bottom side and not from the top.
SF
Silverfox is offline
Old 06-17-2011, 06:35 PM
I guess I need to ask this......
What does it matter if you are looking from the bottom side or the top? The exhaust outlet is still on the wrong side!!
(look at the rear of your car FROM THE REAR....and imagine you slide under feet first....the exhaust outlet is STILL on the left)
However, you can flip the car over and look from the top down to view the tailpipe on the right (or for that matter, view from the bottom up).
Old 06-17-2011, 07:47 PM
I think when they knew that they needed that diagram, somebody said "Even a caveman could draw it". And that's what happened. His name was Fred.
Old 06-17-2011, 08:59 PM
jay loukakis's Avatar
floor jack adapter.
I just ordered one better to be safe, thanks for the info from this site.
jay loukakis is offline
Old 06-24-2013, 07:52 AM
dopplerjeff5000's Avatar
Hello all,
After reading this and many other posts on the topic, it is still very unclear to me where to put the jack stands for front-end type work. In the past I've used the two holes that sit in a little bit from the arrow indicating where to place the jack ... the metal definitely got a little bent when I did this. (Incidentally, should I be worried about this?)
Any input on this matter would be greatly appreciated.
dopplerjeff5000 is offline
Old 12-03-2014, 07:56 PM
Lamestdudeout's Avatar
Originally Posted by dopplerjeff5000
Hello all,
Just did the same thing , what's up with that misleading drawing Name:  08wpb6d.jpg
Over a year later but really
Lamestdudeout is offline
Old 12-03-2014, 08:29 PM
I put jackstands at the flat spots on the front horns.
Old 12-03-2014, 10:00 PM
prod's Avatar
There are frame rails, well the unibody equivalent, that run front to back and are thick layered steel. In the above pic the stand is on it. I use that for jacking and put the stand right next to it on the rail.
prod is offline
RBodeman
07-11-2014 03:35 PM
vettman
05-30-2010 12:18 AM
08blackHHRSS
Tires & Wheels
26
07-23-2009 06:49 PM
pitbull76
03-14-2009 11:31 PM
SindyDix
15
08-01-2006 10:28 PM
Quick Reply: Round jack points for a floor jack
