Electric Power Steering EZ fix no recall
Old 09-12-2012, 05:32 PM
  #51
carmando's Avatar
any news yet of a recall on the power steering motor?
carmando is offline
Old 09-17-2012, 09:28 AM
  #52
David S's Avatar
I seen a mesage that had pictures of how to take out the power steering motor now I can't find it can someone help?
David S is offline
Old 09-18-2012, 08:43 AM
  #53
wmsburghhr's Avatar
it is in the 'how to guide' section https://www.chevyhhr.net/forums/how-tutorial-library-21/power-steering-motor-replacement-w-pics-31289/
wmsburghhr is offline
Old 12-24-2013, 06:03 PM
  #54
FallGuy2005's Avatar
Power Steering, Intermittent
Thank you for answering my trouble shooting conundrum. My power steering periodically goes out; I called the local Dealer to price both the motor and the column. He had sold a few motors but never a column thus statistically it is the motor that is the problem. I Bought the motor today, will replace tomorrow.
Originally Posted by FLORIDA
Like many others soon after the Electric Power Steering recall on other GM like cars, Cobalt, but not HHR, I then experienced the Electric Power Steering problem. It would reset after it cooled down, but it tripped every day. I was able to fix it myself by replacing the Electric Power Steering motor under the dash on the column. It is mounted with 2 bolts. I was told the dealer would not issue a recall and it would cost about $400. I replaced it myself with the new replacement for only $125.
FallGuy2005 is offline
Old 03-06-2014, 08:24 PM
  #55
motoretro's Avatar
Are all years and models of HHR's affected? Were the replacement motors installed as a running change on the last couple years of HHR's? Are these replacement PS motors dated either on the box or part itself?
Thanks,
Motoretro
motoretro is offline
Old 03-06-2014, 09:58 PM
  #56
Thanks,
Motoretro
affected by what? They break.
Old 05-18-2014, 12:37 PM
  #57
happydaze's Avatar
I have a 2006 HHR LT that the power steering light keeps coming on and I lose my power steering. If I shut the car off and restart it, its works fine for awhile. I spoke with the dealer he said no recall issued for the year. What are your recommendations. I don't have $700 the dealer quoted.
Ken
happydaze is offline
Old 05-18-2014, 03:53 PM
  #58
Ken
GM Recalls Older Model Vehicles to Fix Power Steering
Read this link, then take it to your dealer. NOT a recall, a Lifetime Warranty. Seems like a lot of dealers are playing a game of answering your question and not one word more.
But, the part only costs about $115 and takes 30 minutes to do.
I SEARCHed "power steering" and got this thread first suggestion. https://www.google.com/url?q=https:/...CU1hvnVhUsfPGA
Old 05-19-2014, 09:34 AM
  #59
Gsus's Avatar
Hi Guys,
I fixed it by replacing a front bad tire, it has a very small knob under the tire, so it was causing vibration that the computer detected, It was till I changed the front tires that it was solved by itself,
after like 6 months I had the same problem so I checked for any vibration again and it was the front brake pads needed a replacement and was causing small vibrations so I changed the brake pads and it solved the problem again, I havent had the problem since 2 years ago.
Gsus is offline
Old 01-25-2017, 11:04 PM
  #60
motoretro's Avatar
Is GM still doing the recall on the PS motor....
Motoretro
Quick Reply: Electric Power Steering EZ fix no recall
