GM Performance Parts Turbo Upgrade Kit
Dealer install time
Good question ask our new member, what exactly is included in this upgrade? And how is it the specs for the AT and MT are the same? Or is it that the TQ ratings are the only difference and the HP is the same? Any idea on what the dealers will be charging hour-wise for installation?
So the ? still remains what if you have H/P Tuners will be able to adjust it?
Couple questions...
Teh stock ecu adjusts boost depending on certain conditions to keep the hp and torque at 260. Does this ecu do the same? Is there a set boost level?
Also since the ecu does that, will bolt ons increase hp without the ecu compinsating fo the extra air flow etc..?
Will there be other upgrade kits like stage 2? Intake ,turbo back exhaust?
Thank you!
Thank you!
Couple questions...
Thank you!
Thank you!
Sorry, I can not give out any information on future products.
Mine is ordered as well will be here on the 12th/13th.... Install on the 20th....Look AaronSS i'm coming for ya....LOL Aaron New Years get-together my place you coming out? Any others locally swing on by.....South side Alvin, Texas area
