Front Grille Emblem
I finished the modification to the SS emblem and mounted it in the grill a couple of weekends ago. It is the same as the door emblems. I think that it would look better on the intercooler grill but it is a lot more complicated to get it there as opposed to the upper grill that gives immediate access by simply raising the hood.
Try This
C:\Documents and Settings\All Users\Documents\My Pictures\Kodak Pictures\2008-04-15
I'm too cheap to become a premium member so I can't post directly but see if this works. Copy and paste the first line.
I'm not prem either. Having no luck with pic by paste. If you have a picture, you can download it to the forum's gallery and then a link will take us to it.
Upon further review, I would like it on the intercooler grille.
I thought there would be a gap, even if small, between the moudling and the intercooler so I could get under the car and reach up to attach it to the back of the lower grille.
No dice.
How does that lower grille attach to the bumper/moulding? Can it be snapped in and out from the front of the car? It seems like it should, but I don't want to be busting a grille pulling to hard one on side to get it off, only to have it crack.
That's the only way as I can see access to the back of that lower grille, unless I am missing something...?
No dice.
If you want to post a pic I use tinypic. Go to www.tinypic.com upload your pic and it will give you links to the pic. Use the forum or message groups link and copy and paste it into your post and it will show the pic.
