Keyless entry help
Old 05-18-2010, 07:57 AM
tech-guy's Avatar
Latest update.. Called the dealer gave the my VIN number and yes my car does have Keyless entry..The remotes are $65.97 each and to program them is $66.00... I will have to wait on this one... Thanks
tech-guy is offline
Old 05-18-2010, 08:18 AM
Try a couple of other dealers, they don't all price the same.....
Greybeard999 is offline
Old 05-18-2010, 01:17 PM
DarrenMc's Avatar
I haven't had to buy any remotes for the HHR but I bought a couple for an Xterra I had on eBay. I believe i gave $20 which included the programming instructions.
Programming a remote is usually very simple... a few steps that you could possibly find online or more than likely someone on here could relay that info to you.
Give eBay a shot.
DarrenMc is offline
Old 05-18-2010, 01:40 PM
an08HHR's Avatar
YOU CAN NOT program a remote for the HHR unless you have a GM tech 11 scanner $$$$. Either a dealer will have to do it or someone with the scanner. Has been discussed many times in other threads on the same topic.
an08HHR is offline
Old 05-18-2010, 02:50 PM
tech-guy's Avatar
Thanks everyone.. I will go to the dealer and get this done...
Thanks again...
John
tech-guy is offline
Old 05-26-2010, 11:36 AM
DarrenMc's Avatar
This is correct... a scan tool is required for programming.
My bad.
DarrenMc is offline
Old 06-04-2010, 11:01 PM
C-Meth's Avatar
I just did this mod 2 weeks ago. I got 2 remotes off ebay one for $6.00 the other for $8.00. One didnt work I forgot to check to see if it broke loose inside. The dealer programmed my working one in for $45.00. I opened my other remote it was broke free fixed the remote took it to autozone where they had a remote tester and it was working. I am goint to have it programmed when I have a second key made since it has to be added also I believe.
C-Meth is offline
Old 06-07-2010, 07:38 PM
mrsilent13's Avatar
i got the same thing as the op....just one key no fob and i just looked and saw that it does have an AP3 code...and i also found these instructions on another site...do you guys think this will work? also what is the part number for the remote with the remote start?
http://chevroletforum.com/forum/showthread.php?t=20695
Keyless Re-program Instructions
Legend:
Insert key and turn ignition switch to "On"
Follow these steps:
-Press Vehicle information button until "PRESS [checkmark] (set/reset)TO RELEARN REMOTE KEY" displays.
-Press Set/Reset button until "REMOTE KEY LEARNING ACTIVE" displays.
-Press and hold both the Lock and Unlock buttons on the keyless remote for approximately 15 seconds. A chime will sound to indicate that the remote is programmed.
-To program additional remotes, repeat step 3. A maximum of 8 remotes can be programmed to this vehicle.
-Exit programming mode by turning key to "Off" position.
-Test Remote(s)
mrsilent13 is offline
Old 06-07-2010, 07:49 PM
tooter1's Avatar
Legend:
Follow these steps:
-Test Remote(s)
I'm not sure if that procedure will work or not. Don't remember "TO RELEARN REMOTE KEY" an option in the menu but, I do have an '06 so I'm not sure about newer models.
tooter1 is offline
Old 01-22-2011, 07:48 PM
Don06's Avatar
I bought a new remote from a locksmith shop a couple years ago for $35.00 and they programmed it to my 2006 HHR using only the key.
Don06 is offline
Quick Reply: Keyless entry help
