Fixing broken door handles on HHR
Old 07-05-2009, 10:03 PM
snakedoctor62's Avatar
Yes, I tried salvage yards with no success.
snakedoctor62 is offline
Old 07-05-2009, 10:31 PM
oneton's Avatar
They don't have one or don't want to sell it off the door.?
Here is a place not far from your zip code,that has some HHRs
mailto:scottsttx@aol.com
PH# 1 800-955-0210
oneton is offline
Old 07-05-2009, 10:39 PM
tooter1's Avatar
Originally Posted by snakedoctor62
You can always extend the rope out the window and attach a couple of lemons to it. Then park the car in front of the dealership where you bought it. That might tempt the Chevy people to stock that little plastic part as a separate item.
You know what? This might just work.
GM made a bad design. I don't know of any auto that this part isn't replaceable without buying a whole door panel.
I do now it's an HHR.
tooter1 is offline
Old 07-05-2009, 10:41 PM
tooter1's Avatar
Originally Posted by hhrcrafty
C'mon, with a handle like "tooter", you gotta take a little ribbin' about duct tape and bailing wire car repairs in Tennessee.
Well yeah, but I guess I'm lucky and haven't had to do that kind of repair work.
tooter1 is offline
Old 07-18-2009, 08:14 PM
tooter1's Avatar
Another attempt to fix this piece of junk GM plastic.
I'm gonna see if I can find a place that will do a metal casting of this part, might be cheaper than buying a new door panel.
What I did was, epoxy the pieces together then epoxied a piece of metal to the handle, then I drilled pilot holes and put epoxy on the screws and tightened them up.
Put some epoxy in the crevices to give screw some grabbing power.
Also the ends of the plastic pin that holds the handle to the panel broke too, so I just used a screw and nut with threadlocker to keep it in place.
I really hope this works.
tooter1 is offline
Old 07-22-2009, 10:22 AM
cruzdreamer's Avatar
HHR door handle repaired
Just got my door panel replaced because of the door handle being broken....took 3 business days to get the panel ($369 for the panel and labor)...luckily I had an extended warranty so I just paid my $100 deductible. What a dumb design...if we only knew huh!! When I bought this car used a year ago I had a feeling I may be needing a warranty....and I never buy warranties...though I found out I was ripped off bad on it. They wanted $1800 for it....yikes! Don't pay more than a $1000 for one gang!!! Negotiate it like anything else....lesson learned! Boy, I am sorry guys, I really want my Mazda back...I miss the performance and handling of the Mazdas...though they are not perfect cars either! Love the look of the HHR though!
cruzdreamer is offline
Old 08-27-2009, 04:08 PM
dominique7's Avatar
Post Broken interior door handle
OMG! I have the same problem with my driver's side door. I'm in Los Angeles. So I go to the dealer, and I'm about 100 miles past 36,000, so my bumper-to-bumper warranty just ran out. They tell me to get it fixed will be $445 plus tax. (Our tax is now 9.75%.) So of course I have a cow!!! I check to see if I can save money by getting the ENTIRE door panel and installing it myself, and it turns out to be $367.63 with tax. I'm unemployed right now (who isn't), but still, that's a lot of money. So I'm off to Walmart to get epoxy and fix it myself (I hope). I'm also going to write Chevy (for all the good it may do) and ask them if they know a replacement interior door handle runs $400+. I'll let you guys know how it goes.
Dominique
dominique7 is offline
Old 08-27-2009, 05:12 PM
Kinison_fan's Avatar
Originally Posted by tooter1
Thanks for the pics!
I've been following this thread, but somehow missed the pics before (most photos are filtered/blocked at work )
That is a cheap design-but looks like you did the best "DIY/at home" fix-hope it lasts for you.
Maybe someday there will be an aftermarket part, but not likely-even though the HHR is very popular among this group, there aren't a lot of them on the road. And I don't think the handle is shared on any other GM product...
Kinison_fan is offline
Old 10-18-2009, 03:23 PM
chuktaylor2's Avatar
For those of you who are still experiencing interior door handle failure. Try using epoxy let cure and go over the top of it with "the magic putty" (as seen on TV product) or you can generally find a version of it at some local hardware stores. I used the epoxy alone method which only lasted a few weeks, then i used the above method to repair it the second time and there hasn't been a third ( its been about 6 months). Hope this help any of you who really dont want to or just cant afford to spend in excess of $300.00 for a whole door panel.
chuktaylor2 is offline
Old 12-05-2009, 01:44 AM
sharonjohn1234's Avatar
Angry 2006 Chevy HHR inside door handles
WHY can't Chevy sell just the plastic door handle?
[/SIZE]
sharonjohn1234 is offline
Quick Reply: Fixing broken door handles on HHR
