High Mileage HHRs
Old 02-05-2013, 06:20 PM
  #41
rainmanva's Avatar
338,000 miles?! wow my 2010 hhr currently has 70k on it, 34 k when i bought it almost 2 years ago. yes, i do alot of driving but ive maintained it well stayed on top of oil changes, etc. hope i get 338k out of mine!
Originally Posted by Jeff08Panel
I have 338.000 just had to replace alternator last year but other than tires shocks and front upper/control arms and door parts that wore out on my panel door I use 50x a day...I can't say enough good things about these cars...
rainmanva is offline
Old 02-05-2013, 09:03 PM
  #42
That's a lot of panel door opening, hope mine does as well....
SS fan is offline
Old 02-09-2013, 06:47 PM
  #43
chefan's Avatar
have an 07 hhr ..217,000 k on it..runs good!!gets about 650 k to a 60$ tank.started off from a start the other day...gave er a little and it just wanted to burn the skins off lol!only problem i have is the clunk in the front end :/ paid 5000 for it
chefan is offline
Old 04-20-2013, 12:28 PM
  #44
dnutbrown's Avatar
I bought my Canadian lt with the 2.4 5 speed manual. Just turning over 480,000 km or roughly 300,00 miles. Still on the original clutch that will slip if abused very hard but does not in every day driving. Getting a bit of knocking at very light acceleration which is likely either wrist pin wear/piston slap or timing chain/guides wear. I picked up a used 2.4 with 65,000 km last summer and a new clutch but have not put them in yet. I still plan to run this for 1 more year or so to hit at least 600,000 km.
Only problems I have had are front swaybar links - (I finaly just removed one of the links and disabled the sway bar (well over 250,000 km ago) which was only noticeable on the most harsh turns. Both front wheel bearings once and just have purchased another as one is making a bit of noise.
Struts and shocks.brakes and tires as any other car.
This has been the most reliable vehicle I have ever run. I hope my new outback is anywhere close as reliable.
Dale
dnutbrown is offline
Old 04-25-2013, 11:39 AM
  #45
mikiec's Avatar
I have 97K on my 06. Starting to show it's age. Just little stuff. I'll fix it and go another 97K.
Mike
mikiec is offline
Old 04-25-2013, 03:43 PM
  #46
southerncomfort's Avatar
I have 76,000 miles on my 07......regular maintance and a super tune..runs better than when i got it new ...born 10/06...came home on june 11,2007(330 miles). STARTED SHOWING AT CAR SHOWS THIS YEAR..S C
southerncomfort is offline
Old 04-27-2013, 02:03 PM
  #47
alexrckid's Avatar
man...is that 338,000 miles...??? wow...thats great
alexrckid is offline
Old 03-21-2014, 10:56 PM
  #48
InfusionRN's Avatar
Smile High miles
I have a 2010 with 156k on it..because I drive for a living I change the brake pads very frequently. The engine has gone low power on me,transmission beginning to leak,suspension changed..but still running strong. I hope it takes me to 250 plus.
InfusionRN is offline
Old 04-09-2014, 09:48 PM
  #49
Mongosride's Avatar
08 with 307k
My 2008 LT has just turned 307,000. I am a courier and drive from 2000 to 3000 miles a week. Only major replacement was front hubs, and serp belt, other than tires, struts, and front brakes. Still has original rear brakes, and still in decent shape. She still gets 30.1 mpg on a regular basis. Love my ride.
Mongosride is offline
Old 04-10-2014, 07:52 PM
  #50
255,000 klms approximately 156,000 miles , no smoke , no oil drips, runs fine! still lovin' the ride the looks and the mileage!!!!
Quick Reply: High Mileage HHRs
