Driver side speakers - intermittent???
Old 11-06-2013, 09:20 AM
alarue's Avatar
Originally Posted by danbusler
Thanks - but the speakers sound OK when they work, which is at random times - maybe once every week for a hour or a day. - So it it most likely something else.
When I first got the car they did work most of the time, then they worked less and less as time went on. It eventually got to the point where occasionally I would hear a little sound from the front one.
Mine is a 2006 model, and I purchased it in the summer of 2010.
alarue is offline
Old 11-06-2013, 09:36 AM
danbusler's Avatar
Yes, mine worked for a few years and then started to have issues - what you are are hearing is just the tweeters - which always work for me. it's the door speakers that cut out
danbusler is offline
Old 11-06-2013, 11:13 AM
New speaker. The driver side speaker gets water damage from the window.
Old 03-08-2014, 05:38 PM
Rayfl's Avatar
Smile 2006 HHR Left Speakers
I was having problems with left speakers also. On-off, on-off then finally off. Bought a replacement Kenwood receiver and still had problem. Took left front door apart and wired in a different speaker and it worked. I never would have thought that the speakers were bad, was I wrong. Going to order new speakers to replace them all. Not taking a chance with the right side speakers.
Hope this info will help someone.
Good Day.
Rayfl is offline
Old 12-07-2014, 09:18 PM
pmracing's Avatar
My wife's 2006 is having similar problems. The right side is out. She has the basic system. no subwoofer.
Can anyone tell me the ohms of the speakers? I could find out when I tear the doors apart but would like to have the new speakers and have the work done all at the same time as a surprise for her birthday at the the end of December.
What is a decent replacement speaker. I will probably be replacing all four, not yet sure if the tweeters are needing to be replaced.
Thanks in advance.
Mikeeee
pmracing is offline
Old 12-07-2014, 10:02 PM
Thanks in advance.
Mikeeee
Try this link: https://www.chevyhhr.net/forums/clas...speaker-45658/
And don't be afraid to try the Search function we have on this site. I typed in "speaker ohms" and this is 1 of many threads.
Old 12-08-2014, 09:41 AM
alarue's Avatar
Thanks in advance.
Mikeeee
Should be 4 ohms, just a standard automobile speaker. I put some Polk Audio shallow-mount 6-1/2" speakers in the front and was very happy with them. I wouldn't call myself an audiophile, though. Ordered from Crutchfield because they give you everything you need to do the installation, including wiring adapters and a good set of instructions.
alarue is offline
joe gilletly
12-13-2013 03:27 PM
Esalv74
08-18-2012 09:51 PM
jrsharp21
04-14-2011 07:48 PM
edb
08-22-2010 10:41 AM
Katymaywriter
07-03-2010 06:59 PM
Quick Reply: Driver side speakers - intermittent???
