Suspension Noise
Old 11-03-2013, 11:04 AM
prod's Avatar
Originally Posted by hozer
Hello fellow local NJ HHR owner.I get that squeak when it is cold outside also.It happens when I go over "dips" in the road but does not happen over bumps.Can't tell if it is from the front or rear.As you the colder it gets the more noticeable the sound is.Goes away when driven a little bit and never happens when it is warm outside.I just ignore it for the most part.Car drives fine.
Sounds like the swaybar bushings, you could try lubing them to test.
And Hozer is a Canadian expression, are you sure youre allowed to use it?
prod is offline
Old 11-04-2013, 09:51 AM
Bob and Doug , said just this once, eh!
thunderstruck88
30
04-26-2015 04:41 PM
chefhhr
16
07-08-2012 05:47 PM
teech
12-28-2011 04:18 PM
xzombiex66
05-23-2008 12:34 PM
Quick Reply: Suspension Noise
