Oil life indicator reset
Old 05-16-2010, 12:41 PM
cleerdin's Avatar
Could someone please tell me how to reset the oil life indicator on my 2007HHR? Thanks
cleerdin is offline
Old 05-16-2010, 01:27 PM
1970judge's Avatar
Turn the key to the on position and hit the gas 3 times..then crank it up and it should reset.
1970judge is offline
Old 05-16-2010, 01:29 PM
gravett1's Avatar
The easiest way is to turn the key to the on position & hit the gas pedal 3 times & it will clear.
gravett1 is offline
Old 05-16-2010, 02:34 PM
ecl
ecl's Avatar
Or you can turn the key to the on position and press both the info and reset button at the same time for a few seconds and then scroll through the menu till you hit the oil life reset and just hold the reset button until it says reset/acknowledged.
ecl is offline
Old 05-16-2010, 08:27 PM
DirtyJim's Avatar
Interesting. My 2010 is quite simple...once I select the oil life by using the "info" button, I simply hold the "return" button for a few seconds until it resets. I guess this is a newer feature?
DirtyJim is offline
Old 05-16-2010, 09:01 PM
bowtieboy68's Avatar
dirty, that's how I do it in my 06
bowtieboy68 is offline
Old 05-17-2010, 10:07 AM
Cajun's Avatar
Same way in my 2008...
Cajun is offline
Old 05-17-2010, 09:15 PM
StaticAZ's Avatar
The manual for my 2010 says to do do as described above with the info button but for some reason, it did not work. I read it again and it said with the 2.2 engine, you can also depress the gas pedal 3 times within 5 seconds after turning the ignition on and that did it.
StaticAZ is offline
SmootHHR
05-31-2011 01:27 PM
kornellred
05-10-2009 12:34 AM
RUDEINC
02-26-2009 11:15 PM
teech
07-05-2008 09:56 PM
MikeX
04-30-2006 08:30 AM
Quick Reply: Oil life indicator reset
