Help! How to change door speakers
Old 10-26-2007, 10:31 PM
sleestack's Avatar
Does anyone have a how to on changing the door speakers. Using the search I found a link but it was dead. I'm looking for something with pictures.
Also would anyone know how the stock door speaker and tweeter is set up on an 06 2lt. I'm replacing the stock with components but need to know what color the positive and neg is and if the stock system uses a crossover. In other words I need to find the speaker wires before they are split to the tweeter and woofer of the stock system so I could feed that to the aftermarket system's crossover
sleestack is offline
Old 10-26-2007, 10:56 PM
Lee3333's Avatar
Most tweeters I have seen have the cap right on it. I changed my 4 door speakers and left the factory tweeter, and it sounds ok (my friend that owns a stereo store said there was no reason to change it, although I have considered it). The wiring to the speakers is hard to change, so I just spliced the wires to the factory harness. When I connected it to my head, I ran my wires to the factory amplifier and spliced into the wires going to the speakers-they look about 16 gauge which is adequate for moderate power.
As for the colors of the wires-PM me your email and I will send you the diagram. To change the speakers, simply pull off the cover behind the door pull and unscrew the torq bolt, then pull up the oval rubber piece on the arm rest and remove the 2 torq bolts there, then remove the push pin from the edge of the door that faces you when you open the door. After that, starting at the top front (by the mirror on the front doors) pull the panal to detach the snaps. Work your way around the entire door, then pull the buttom out and tilt it. Finally, you have to lift the panal keeping in mind that it is very tight around the top (where the seal by the window is). Rather than unplugging the harnesses, I use wire to tie the panal around the window frame so it doesnt just hang there. A single bolt holds a plastic piece to the door-remove it along with the speaker. This way, you can unplug the seaker and have an easier time removing the 4 screws that hold the speaker in place.
If I may suggest-get some Dynamat Extreme and stick it all around the inside of the door panal. It is expensive stuff, but it really makes a huge difference. I picked up a kit with 9 large pieces from Amazon.com for a little over $100. I want to use more on the outside of the door, under the panal (I was told by the Dynamat people that it will improve sound deadening from outside noise and further insulate the door so that sound comes just from the speaker itself and not all of the little openings in the door.
Lee3333 is offline
Old 10-27-2007, 10:33 AM
courthousedeb's Avatar
Not sure if this info will help, but got this from another thread. Hopefully this will be of some help to you or others on the forum.
Originally Posted by DeutscheDoggeDriver
As for figuring out my wiring...
I am grateful for any feedback I can get, and I want to thank GCarp for posting the diagrams, unfortunately they're just too fuzzy.
I've got some good diagrams, and I think they are correct for my car. I found them in the following post: https://www.chevyhhr.net/forums/audio-video-17/premium-stereo-question-1676/, and I'll repeat the diagram links here:
http://n8zcc.com/pics/HHR/Radio.gif
http://n8zcc.com/pics/HHR/Audio_Amp.gif
These drawings have the wires running from the radio to the amp labeled as "low level audio signal" - to me that means line-level/pre-amp level. This doesn't jive with what others (like hhrcrafty) are telling me. Of course this is probably only on the "premium" sound system, which I *think* was originally in my car. So I remain confused.
courthousedeb is offline
Old 10-27-2007, 04:23 PM
sleestack's Avatar
That adid it thanks. I'm changing out the tweeter because the speaker are infinity kappas and I'm sure the system would work better with those vs. stock.
So according to the diagram the wooffer and tweeter are getting a full range signal, it's just the line that is being split, am I right?
The whole point is the the hhr's highs seem muffled complared to the speakers I have in my car.
scottyj1
Mods - Interior
04-14-2015 05:55 PM
shepNfl
07-07-2008 08:37 PM
db0001
10-19-2007 10:50 AM
dnbguy86
11-13-2006 01:30 PM
Quick Reply: Help! How to change door speakers
