oil filter
Old 02-26-2008, 04:12 PM
asherdav's Avatar
Smile oil filter
What a shock to find a element in the new filter box. Now where to put it? 2.2 08
asherdav is offline
Old 02-26-2008, 04:23 PM
Black Rose's Avatar
Here's where to put it
https://www.chevyhhr.net/forums/maintenance-upkeep-50/how-change-your-own-oil-10546/
Black Rose is offline
Old 02-26-2008, 05:33 PM
SIRESMERPH's Avatar
you can take that filter of yours and stick it where the sun dont shine....
right up under the hood cus that's where it goes...yep!
SIRESMERPH is offline
Old 02-26-2008, 08:25 PM
Smoke Wagon's Avatar
looks like the write up didnt mention replacing the o-ring on the filter cap.
I think the authoir just forgot to mention it, but the filter element should come with a new filter cap o-ring. Change that, and smear a little new oil around the o-ring to prevent any tearing as it goes in.
Smoke Wagon is offline
Old 02-26-2008, 08:34 PM
Lone Ranger's Avatar
Why replace the o-ring if its still in good shape?
Lone Ranger is offline
Old 02-26-2008, 09:56 PM
...I always replace any o-ring when a new one is supplied. If it's subjected to corrosives, pressure, heat cycles, expansion and compression, and is made of silicone or rubber, all I ask is...
why NOT change it? The filter comes with a new one. And if the old one should fail, it'll cause a bigger mess than the current drain plug design
Just my 2 cents.
Old 02-26-2008, 10:15 PM
oneton's Avatar
Whats wrong with the current drain plug design???
Works just like all drain plugs, you have to hit the drain pan or get a bigger pan
oneton is offline
Old 02-26-2008, 11:29 PM
Black Rose's Avatar
The AC Delco filters that I buy do not come with an o-ring. I think only Wix filters come with the spare o-ring.
Old 02-26-2008, 11:35 PM
Thank you Black Rose....I was thinking the same thing.
Purchased a dozen Delco filters so far (shared with friends). NONE came with the "gasket". Not that it's not a bad idea.
Oh you know...I think if you purchase the Delco filter that comes with the filter cannister lid, they also provide the o-ring.
Old 02-27-2008, 07:11 AM
The Pure One filters I buy don't have the o ring. It also looked fine and sealed well since then. The o-ring itself does not touch oil.
Quick Reply: oil filter
