Replaced side marker bulb
Old 03-13-2008, 04:42 PM
shaginwgn's Avatar
Other night I noticed my back driver side marker light wasn't lit. Today, since HHR was clean, was 55 degrees, and was sunny her, I decided to check the other lights and replace the burnt out one. I found out that the front driver side marker was also not lit Pulled off other side marker on back and put in driver side. Luckily it worked and wasn't an electrical issue. Got them both burnt out bulbs replaced and want to give thanks to Applenut for the tips on the silver star replacement thread. Only took me minutes to replace them. Has anyone else had to replaced the side marker bulbs yet?
shaginwgn is offline
Old 03-13-2008, 05:02 PM
I've got a front sidemarker that doesn't light up, I've been meaning to do this for a couple of weeks. Thanks for the reminder!
jx3 is offline
Old 03-13-2008, 05:30 PM
shaginwgn's Avatar
bulb number 194 or 194LL(long life) or 194na(yellow). On the front after releasing clip on bulb holder and wire, you have to give it a slight twist left to get bulb and bulb holder as it has a small thread like system to hold it in place
Old 02-03-2010, 08:31 PM
SmootHHR's Avatar
Both my passenger side markers were out. Got the back one out easy since there was a screw holding it in...how do you get the front passenger corner lens out?? I'm really hoping you all aren't going to tell me that I have to pull out the fender liner...
SmootHHR is offline
Old 02-03-2010, 08:38 PM
roofer1976's Avatar
BINGO!!!
Sorry...it's easy, once you get the liner off.
roofer1976 is offline
Old 02-03-2010, 08:40 PM
SmootHHR's Avatar
Well crap..................guess I'm not doing that tonight Thanks for the input though
SmootHHR is offline
Old 02-03-2010, 09:25 PM
Saltine's Avatar
I have a couple of side markers out as well but I think it was from when I removed the markers to tint
Saltine is offline
Old 02-04-2010, 07:28 AM
SmootHHR's Avatar
I ended up doing it last night anyway...I couldn't stop thinking about that stupid light! And yes roofer, it was really easy once I got the liner loose.
Saltine, I'd love to see some pics of the tinted lens'. On one of my SHO's I had the tail lights sprayed and they looked AWESOME! You could still see the reflectors when lights hit them but they looked black as night during the day. 90% Clear, 10% PPG Onyx Black, 3.5ish coats
SmootHHR is offline
Old 02-04-2010, 07:34 AM
twistrman's Avatar
one of these days when it's clean i'll take a couple hots of mine too. I just took window tint and wrapped the reflectors in it. Once installed they look fantastic, they still reflect but blend right in with the vehicle. If I ever need to go back to stock, i can just remove the tint.
twistrman is offline
Old 06-01-2012, 10:09 PM
malemann's Avatar
On my 2008 HHR the rear side light was just a simple push in bulb ...while the front requires a 2 pronged bulb.
malemann is offline
unique_w
"How To" Tutorial Library
48
05-09-2016 07:32 AM
jax1457
11-23-2011 07:03 PM
bossrod
Maintenance and Upkeep
09-29-2010 04:15 PM
scuba05477
03-15-2010 07:20 PM
Skatetheglobe
20
04-18-2007 05:32 AM
Quick Reply: Replaced side marker bulb
