How do you remove the chrome rings around the air vents?
Old 07-19-2008, 12:04 PM
Jeff®'s Avatar
I want to paint these flat black, because I hate chrome for medical reasons. (don't ask) There doesn't seem to be an obvious way, and I don't want to snap/bend/damage anything. Anyone know?
Jeff® is offline
Old 07-19-2008, 03:22 PM
SLVR FOX's Avatar
id like to know to.
my daughter broke my passengers side vent and i need to replace it.
SLVR FOX is offline
Old 07-19-2008, 10:35 PM
You have to remove the accessory trim plate to reach the three screws that hold the vent. Use a plastic trim tool to pry the plate off. As far as i know the chrome ring is part of the vent assembly.
Originally Posted by SLVR FOX
id like to know to. my daughter broke my passengers side vent and i need to replace it.
I think you can access the three screws that hold the right vent by using a plastic trim tool to pry the end cap off the side of the dash.
Old 07-21-2008, 03:15 AM
Yonash's Avatar
follow this guide to get the panel off (also called the waterfall elsewhere on these forums), and there are three screws on each vent. IIRC there are loosly fitting tab-in-slot type things on the edges that hold the chrome ring in place, 3 of them i believe. as for the vents out near the doors, not a clue how to get those out of the dash...from underneath the dash somehow i'd imagine
Yonash is offline
Old 07-21-2008, 05:47 AM
Jeff®'s Avatar
Thanks
Of course, they didn't show how to put it back.
Jeff® is offline
Old 07-23-2008, 05:53 AM
Jeff®'s Avatar
It turned out pretty good.
Jeff® is offline
Canesfinsfan83
08-26-2015 09:18 AM
endurorob
03-28-2014 05:40 AM
urbexHHR
27
10-02-2009 09:53 PM
Scarecrow
08-10-2007 10:35 PM
giant96
7
07-01-2006 08:38 PM
Quick Reply: How do you remove the chrome rings around the air vents?
