Go Back   Chevy HHR Network > Specific Technical Discussion > Fuel Economy - Hypermiling > What tire pressure are you running?
Fuel Economy - Hypermiling Dedicated to discussions on fuel economy improvements and related modifications.
Old 07-21-2008, 08:06 AM   #1
StormChaser
Member #: 7654
I'm running 32 psi (cold) all the way around and have averaged a bit over 28mph overall over the past 800 miles. I was thinking of pumping the tires up to 40 or so and seeing what that does to mileage. So...what are y'all running?
StormChaser is offline   Reply With Quote
Old 07-21-2008, 08:52 AM   #2
jdmcomp
Member #: 4582
Poor tradeoff, tires for gas. Also can a safety issue on several grounds (see Ford Explorer rollovers for example). Do not exceed the tire pressure max listed on the tire. What will work is to purchase the low rolling resistance tires coming on the market. These tires can be hard compounds so you will loose some traction in dry conditions, lots in wet conditions, and all in snow and ice conditions. Having lived 10 years in DC you really don't get any real snow or ice so that is not a problem.
With all of the legal out of the way, it is important to keep the tp up to spec for your vehicle. The gains of increasing tp are small but the losses for low pressure are great. Diminishing returns problem. Running the smallest tallest tire (real retro look) you can find will help but probably more from tire dia then anything else. You will lose ride and handling somewhat.
jdmcomp is offline   Reply With Quote
Old 07-21-2008, 08:56 AM   #3
twistrman
Member #: 7282
Images: 16
I think mine are at 35 cold and when hot can get up to 38. This is how I got them from the dealer and haven't changed a thing on them yet. The TPM's haven't yelled at me either, do i'm just going with it being correct.
2008 Black 2LT, ebony Interior, sunroof, chrome roof rails, high polished 17" wheels.
Mods: Stubby Antennae, Blacked out Bowties, Yellow TTR Sway Bar, Yellow Calipers, Black LED tails
twistrman is offline   Reply With Quote
Old 07-21-2008, 10:31 AM   #4
TY&HHR
TY&HHR's Avatar
Member #: 2266
I checked my tire pressure one day when I came out from work and the tires sitting toward the sun was 2# more in pressure. My wifes uncle told us he replaced his air w/ nitrogen and it made a huge difference, so I contimplating changing also. I know from being around racing it makes a difference.
____________________________________
2008 White 2LT cashmere leather & sunroof
NEW PROJECT... 1952 CHEVROLET 3100 "RAT ROD SSR"
TY&HHR is offline   Reply With Quote
Old 07-21-2008, 11:20 AM   #5
an08HHR
Member #: 4329
Images: 3
I have the 17" hi polished Alum that came w/car and the recom. pressure is 35 cold.
an08HHR is offline   Reply With Quote
Old 07-21-2008, 11:21 AM   #6
twistrman
Member #: 7282
Images: 16
i thought i had read the nitrogen really doesn't do much at all. Could have been wrong as well, but i think it's pretty much in the air (ha ha, sorry). we should call myth busters on it.
Old 07-21-2008, 11:23 AM   #7
an08HHR
Member #: 4329
Images: 3
nitrogen just doesn't leak out as fast as reg air which is about 78% nitrogen anyways. Just check your tires on a regular intervals and you'll be OK
Old 07-21-2008, 03:01 PM   #8
TY&HHR
TY&HHR's Avatar
Member #: 2266
Nitrogen doesn't expand as the temp rises like air does. Never heard that is leaks out slower.......nothing should leak out unless there's a hole. But, calling Mythbusters is not a bad idea.
Old 07-21-2008, 03:22 PM   #9
mitzkity
Member #: 1835
Images: 34
I run at 40 because I have whitewalls that last longer that way.
Mitzi, my surfer girl cruiser
SoCal HHRs Map
mitzkity is offline   Reply With Quote
Old 07-21-2008, 03:34 PM   #10
Desert Coyote
Desert Coyote's Avatar
Member #: 1633
Images: 176
Running at 42 cold - makes the road noise a bit louder but maximizes my mileage.
STITCH 9/30/05-2/21/07
Did what he was designed to do.
Stitch II was born 1/10/07
AWARD WINNER 2008
HHR NATION - Nine days, 4000 miles, two people, one car.
Desert Coyote is offline   Reply With Quote
