Go Back   Chevy HHR Network > General Discussion > Problems/Service/Repairs > Keyfob battery low indicated in DIC
Old 01-06-2009, 11:57 AM   #1
onlyron
Member #: 4518
Question Keyfob battery low indicated in DIC
My friend has finally seen the light and bought a gently used 2007 HHR LS. His "Low Battery Keyfob" message is being displayed. He replaced the batteries in both but the message is still there. Could it be a battery post loose in the keyfob? What else does he need to do? Or is this a "dealer needs to look at it" thing?
onlyron is offline   Reply With Quote
Old 01-06-2009, 12:16 PM   #2
Old Lar
Member #: 4311
Images: 16
Never knew the DIC ever said that...
Old Lar is offline   Reply With Quote
Old 01-06-2009, 12:21 PM   #3
afs9
Member #: 4328
Images: 117
I have an 07 2LT
It does this?!
Dang...guess time to RTM again! cool...
Maybe the DIC needs to be reset?
07 2LT - Sirius Blackie
Experience is the hardest teacher,
you get the final exam before the lesson.--Vin Scully
http://www.socalhhrs.info
afs9 is offline   Reply With Quote
Old 01-06-2009, 02:46 PM   #4
ChevyMgr
Super Moderator
Member #: 4865
Images: 707
2007 DIC can display the following:
AUTO LIGHTS OFF
AUTO LIGHTS ON
BATTERY SAVE
BRAKE FLUID LOW
CHANGE OIL SOON
CHECK CHARGE SYSTEM
CHECK GAS CAP
CRUISE ENGAGED
DOOR AJAR
ENGINE POWER REDUCED
GATE AJAR
ICE POSSIBLE
KEY FOB BATT LOW
LOW COOLANT LEVEL
LOW FUEL
LOW OIL LEVEL
LOW TRACTION
POWER STEERING
PARKING BRAKE
SERVICE AIR BAG
SERVICE VEHICLE SOON
START DISABLED
I think this could be a key fob, BCM or programming issue. I have yet to see one that actually needed a battery. He needs to go see his dealer.
Old 01-06-2009, 02:47 PM   #5
an08HHR
Member #: 4329
Images: 3
Owner Manual only states : The KEY FOB BATT LOW message in the
vehicle’s DIC will display if the remote keyless
entry transmitter battery is low.
Notice: When replacing the battery, use care
not to touch any of the circuitry. Static
from your body transferred to these surfaces
may damage the transmitter.
To replace the battery in the remote keyless entry
transmitter do the following:
1. Use a flat thin object to separate the bottom
half from the top half of the transmitter.
2. Remove the battery and replace it with the
new one. Make sure the positive side of the
battery faces up. Use one three-volt, CR2032,
or equivalent, type battery.
3. Put the two halves back together. Make sure
the cover is on tightly, so water will not get in.
Under normal use, the battery in your remote
keyless entry transmitter should last about
four years.
an08HHR is offline   Reply With Quote
Old 02-03-2009, 06:21 PM   #6
donbrew
Member #: 13699
Images: 4
Also, while you are inside the fob check to make sure all 3 solder points are still good on the battery hold down thingy. When you remove the old battery be sure to pull the circuity board away from the rubber seal/button holder, then slide the battery out and then in, DO NOT LIFT THE TANG TO PULL THE BATTERY UP/OUT. I repaired mine by soldering the tang back onto the circuit board, but no guarantee it does not do $55 damage for new fob.
Don
donbrew is offline   Reply With Quote
Old 02-03-2009, 06:54 PM   #7
Jdans431
Member #: 5763
wow did not realize that the DIC had so many messages programmed in. Sometimes these cars continue to suprise me
JD1HHR - Personalized Plate, Painted Brakes, billet grill, smoothie door locks, wooden cargo floor, avs vent visors
Jdans431 is offline   Reply With Quote
Old 02-04-2009, 07:19 AM   #8
Jeff®
Member #: 6995
Images: 412
"Low Fuel" on my DIC all the time.
(childish fodder)
"The Fancy Red Car"
25 Feb 08
Jeff® is offline   Reply With Quote
Old 02-04-2009, 09:33 AM   #9
HipHotRod
Member #: 5227
Images: 72
Mine asks, "paper or plastic?"
HipHotRod is offline   Reply With Quote
Old 02-04-2009, 10:48 AM   #10
Jdans431
Member #: 5763
Really got surprised today when mine asked to be cleaned. apparently mine does not like winter
Tags
keyfob battery
