Rear Turn Signal
Old 01-06-2009, 04:38 PM
andoll83's Avatar
Rear Turn Signal
I bought new rear turn signal bulbs, but I can't figure how to get to them!
andoll83 is offline
Old 01-06-2009, 04:40 PM
Page 5-43 of your owner's manual.
online owner's manuals
jx3 is offline
Access is located on the inside quarter trim panel. You will see an access panel that is about 8-10 inches tall and 4-5 inches across. Pop it out and you can get to the bulb.
Old 01-06-2009, 04:44 PM
halfpanel08's Avatar
open your back hatch door, look to the right or left.. there is a oval piece that pops out and then your bulbs are right in there.. you can do it, i got faith n ya
halfpanel08 is offline
Old 01-06-2009, 05:22 PM
andoll83's Avatar
yeah that was the first thing i did, but there seems to be a barrier of very thick foam permanently glued in
andoll83 is offline
Old 01-06-2009, 06:10 PM
You are the second person to say that on this site. Strange deal. Must of been a production change. Since I don't know how the foam is secured I don't know how to tell you to get to them except to say start pulling.
Old 01-06-2009, 06:36 PM
HHorange's Avatar
Yes there is a foam insert..... it fits in really tight. No it is not glued in.
You just have to pull it out carefully so as not to rip it. I actually found it easier to start by pushing in on it first. I have had both of mine out to do trailer hitch wiring.
Pull out the plastic trim panel
Pull out the foam,
Unplug the wiring from the light
Turn the bulb holder appx. 1/4 turn. You can actually look in through the taillight lens and see which way you need to turn it. (It also helps to look through the lens to reinstall the bulb holder).
Pull the bulb out of the holder and replace with the new bulb.
Put it all back in reverse order..... take you all of 15 minutes tops
HHorange is offline
Old 01-06-2009, 10:00 PM
andoll83's Avatar
thanks!!
andoll83 is offline
Old 01-06-2009, 10:13 PM
Uma
Uma's Avatar
Pull out the foam,
I agree, I think it is a thing with the premium sound package. I got them out..but never got them back in the right way. Todd (Uma)
Uma is offline
Old 01-06-2009, 11:03 PM
ivtech's Avatar
The foam I had was 2 pieces glued together 1 piece had holes and the flat backing.
ivtech is offline
Quick Reply: Rear Turn Signal
