Go Back   Chevy HHR Network > General Discussion > "How To" Tutorial Library > Removing the inside door panel
Old 02-07-2009, 02:52 PM   #1
orangutanHHR
orangutanHHR's Avatar
Member #: 7224
Images: 20
Has any member ever removed the insde front door panel? If so please l take a few minutes and tell me how so I do not break anything. Thank members.
orangutanHHR
orangutanHHR is offline   Reply With Quote
Old 02-07-2009, 02:55 PM   #2
HillsdaleHHR
Member #: 1788
Images: 8
See this thread: http://chevyhhr.net/forums/showthrea...nel#post249849
"Life is what happens to you while you're busy making other plans." - John Lennon
HillsdaleHHR is offline   Reply With Quote
Old 02-07-2009, 02:56 PM   #3
GDZHHR
Member #: 1751
Images: 708
There is a thread or two..................
Basically there are two screws at the bottom of the door pull under the rubber insert, and one more in behind the cap behand the door handle. One pin on the door jam section the you push in to take out. Then just grab and pull around the lower edges. You will need to then disonnect the handle and switched to remove completely.
MIKE—“Over Qualified & Under Educated”
"A fool always finds a greater fool to admire him." Nicolas Boileau-Despraux
GDZHHR is offline   Reply With Quote
Old 02-08-2009, 07:56 AM   #4
orangutanHHR
Member #: 7224
Images: 20
You guys are great. That is why this works for all of us. Thanks again.
orangutanHHR
Old 02-19-2009, 05:00 PM   #5
wagoneer
Member #: 6872
Images: 10
After you take it out is there any way to swap out the center section? I was thinking about changing the center to black(my panels are gray).
wagoneer is offline   Reply With Quote
Old 02-19-2009, 05:51 PM   #6
dbfruth
Member #: 1430
The part that threw me the first time I removed the door panel was the little clip on the rear facing part of the door at armrest level. The center part pushes IN which releases the clip assembly part so it can be removed. when you reinstall you pull that part so it is sticking up and push it flush to lock it. It makes more sense when you see it.
2009 Ford Fusion SE
1999 Jeep Cherokee- 198,000+ miles and still going strong.
Former Ride
2007 HHR 2LT - Born 9/6/2006 - Traded 3-14-2009
dbfruth is offline   Reply With Quote
Old 02-19-2009, 11:11 PM   #7
Yonash
Member #: 5606
Images: 89
the part i never got was how to unhook the handle...i had bear of a time trying to figure it out, and gave up lol.
-------------------------------------------CHRIS------------------------------------------
Green Monster - 1970 Chevrolet C/20 2wd LWB 350/350 - Towing/Project
Tempest - 1991 Chevrolet Camaro RS 305 TBI - Track Project
Phoenix - 2008 Chevrolet HHR SS LNF 5-spd - Daily Driver
(Unnamed) - 1979 Honda CB650 - Never-ending Fixer
Yonash is offline   Reply With Quote
Old 03-05-2009, 10:48 PM   #8
snakedoctor62
Member #: 14189
Both the front seat interior door handles have broken on my daughter's 2006 HHR.
Now I get to try and remove them so I can manufacture a repair. This is the only post I have seen about removing the interior door panel. Thanks
snakedoctor62 is offline   Reply With Quote
Old 03-11-2009, 01:39 AM   #9
mchuntley
Member #: 4282
Broken, as in cracked down the middle?
If that is it, I have the same problem. How do you think you want to fix it?
matt
Matthew...
2007 HHR LS, Sport Red Metallic, Alloy Wheels
My current Mod List is Here ...
*!*!*I am riding in the ADA Tour De Cure 2012 Ship to Shore in Long Beach, Support me if you dare!*!*!*
mchuntley is offline   Reply With Quote
Old 05-29-2013, 01:45 PM   #10
edgarfrog
Member #: 17258
I got the damn inside door panel off, but when I put it back on, it's all loose and wiggly. I can't get the snaps around the perimeter to go back in. It's tight where the metal clips are up by the window, and of course where the screws are holding it into place (by the handle), but around the perimeter it just kinda hangs there.
edgarfrog is offline   Reply With Quote
