Where do you have your GPS mounted?
Old 02-15-2009, 04:17 PM
TEB-HHR's Avatar
Where do you have your GPS mounted and how? Pictures please...
TEB-HHR is offline
Old 02-15-2009, 04:34 PM
catdaddy137's Avatar
dash cubby box thingy
my is just sitting in my dash cubby/glove box thingy. i plan to mount it in there and wire it inside the dash. i believe the safest place is in the bottom center of of the winshield , but that would be harder for me to reach. even with mine mounted where it is , it is still easy for me to loose track of what is going on in front of me , when trying to program it. the further it is away from the windshield the less safe it is.
catdaddy137 is offline
Old 02-15-2009, 05:04 PM
GRUMPEE's Avatar
GRUMPEE is offline
Old Lar's Avatar
Stuck to the windshield over the speedometer/tac cluster.
Old Lar is offline
Old 02-15-2009, 05:45 PM
twistrman's Avatar
I stick mine with the suction cup mount in the left corner of the windshield. It it isn't obstructing my vision in any way but it there for a quick eye glance if i need it. Plus it is in range if i need to reach forward and modify anything. I used the same spot on my wife's aveo, but since her windsheild is huge compared to ours, it is pretty far out of range.
I also just plug into the cig adapter and drape the cord. It goes with me to different cars so a perm. install is out, and i'm too cheap to buy another charger. If i were to hard install i would open up the dash, install a second cig adapter inside, and a switch on the console, run the wire up through the dash and either have it come out of the console for an easier stretch over, or go all the way to the pillar and have it come out. The battery on the tomtom isn't great so i like to have it plugged in.
He's my photo. And yes, i am driving 80, while passing a semi, and taking a photo (while getting 28mpg!). Most likely no hands on the wheel. I live dangerously...
twistrman is offline
Old 02-15-2009, 06:20 PM
suburbanjunior's Avatar
I bought a sticky mount from ebay. It works well for me.
suburbanjunior is offline
Old 02-15-2009, 07:10 PM
djnixtre's Avatar
Hey, mine's there too!
You might be interested in this mounting hinge for the dash cubby, I almost bought it:
http://cgi.ebay.ca/Clever-GPS-Mounti...1%7C240%3A1318
djnixtre is offline
Old 02-15-2009, 07:58 PM
GRUMPEE's Avatar
Clever idea for the cubbyhole, but after looking at your's & suburbanjunior's mounting solutions I decided to follow suit and regain the storage space in the cubby
Last edited by HillsdaleHHR; 02-15-2009 at 07:59 PM. Reason: Removed pic from quote
GRUMPEE is offline
Old 02-15-2009, 08:06 PM
skyeglen's Avatar
Mines in the same place, center of the dash like the 2 above. Easy to reach and can be pivoted around for the "co-pilots" use. I did wire in 2 outlets in the compartment behind it. One switched thru the key for the radar dector and one constant hot for the Garmin.
skyeglen is offline
Old 02-15-2009, 08:30 PM
clever mount
http://cgi.ebay.ca/Clever-GPS-Mounti...1%7C240%3A1318[/QUOTE]
i really like that "clever mount" on/in the ebay link. but i do not like the $29. i'm thinking about puttn mine in there on top of a small peice of wood-so it can be seen- , with some velcro. my gps has some kind of battery or antenna thing that plugs into the bottom of it. this is widder than than most gps and this why i think it will work. i don't think most gps have this wide thing that plugs in the bottom and back. it is nextar w/backup cam. i'll post pix if i ever get to mount it. if you like this idea but your gps is not wide on bottom , you can make L shape out of wood , attach with velcro. edit - it was $29 canada$ = $23.47 us. still 2 much.
Quick Reply: Where do you have your GPS mounted?
