Where is the Fuse Box ???
Old 06-13-2006, 08:22 PM
blackout's Avatar
I cigerette lighter isn't working and I want to check the fuse but not sure where it is
blackout is offline
Old 06-13-2006, 08:30 PM
courthousedeb's Avatar
There are two of them and I'm not sure which one the fuse for the lighter is in. One is under the hood and you can see where that is here. The other one is behind a panel on the front passenger side of the center console. Just pull the panel off carefully and I would venture to guess that the fuse for the lighter would be in there.
courthousedeb is offline
Old 06-13-2006, 08:33 PM
Tokyo's Avatar
Here is the owner's manual: https://www.mygmlink.com/pdf/go2cont...et/2006hhr.pdf
Fuse #29 under the hood for the lighter. There's also a fuse panel on the passenger side of your center console, all the way forward, just pull it out if you need access.
Tokyo is offline
Old 06-13-2006, 08:36 PM
Firewatcher's Avatar
The owner's manual has great diagrams of both panels. I find that the manual has helped me more than once, although CourthouseDeb explained to me where the interior dimmer switch was. (Right on the console in front of me)
Firewatcher is offline
Old 06-13-2006, 08:38 PM
blackout's Avatar
does the fuse box on the passenger side have the word fuse on it. I check for it but didn't see it . And didn't want to just start trying to pull around the plastic on random panels
blackout is offline
Old 06-13-2006, 08:40 PM
No it doesn't, but it runs along the floor right next to the center console. Don't worry...you won't hurt it. It pulls right out.
Old 06-13-2006, 08:43 PM
SindyDix's Avatar
wow, 382 pages worth!
SindyDix is offline
Old 06-13-2006, 08:45 PM
Tokyo's Avatar
Just some light reading, y'all...
Tokyo is offline
Old 06-13-2006, 09:20 PM
dbarberaz's Avatar
Owner Manuel whats that? Are they aftermarket Mike you have any and do they come color matched?
dbarberaz is offline
Old 06-13-2006, 09:32 PM
SindyDix's Avatar
Owner Manuel whats that? Are they aftermarket ....Christmas wish list: Anything for my HHR
Now there a great Christmas gift if your HHR diden't have one in it's glove box when bought it new!
SindyDix is offline
Quick Reply: Where is the Fuse Box ???
