Sponsored by Ultrarev
Click Here
Old 03-15-2010, 10:18 AM   #1
oldford
Member #: 12559
Lower Control Arm Bushing?
My 2006 LT lower control arm is banging into the sway bar on rough roads. I can see the shiny spot where the contact is being made. I think the lower control arm bushings are worn out. Anyone have experience with the Mevotech lower control arms? Other thoughts? I've got new sway bar bushings and ends and struts all ready. 95k on it, all hard use, dirt and gravel roads, etc.
TIA, Eric
oldford is offline   Reply With Quote
Old 03-15-2010, 10:53 AM   #2
WillBeck_CobaltSS
Member #: 19842
link to the mevotech? good time to upgrade to FE5 components i think :)
WillBeck_CobaltSS is offline   Reply With Quote
Old 03-15-2010, 11:49 AM   #3
oldford
Member #: 12559
Mevotech lower control arms are sold by Rock Auto and others, apparently the only aftermarket available. What's an FE5 upgrade entail? My glove box door carries an FE1 code.
Thanks, E
Old 04-07-2010, 05:39 PM   #4
WillBeck_CobaltSS
Member #: 19842
The FE5 suspension is standard on the SS cobalts. Since we can share just about every other suspension component, why not control arms?
FE5 arms are made of aluminum, and are much better than the standard FE1 variety.
Old 04-07-2010, 06:00 PM   #5
oneton
oneton's Avatar
Member #: 1442
Images: 33
I was thinking FE5 was springs & shocks only
06 Silverstone HHR LS 2.2 auto; airaid, T924, 20% tint, emblems on hood side, fullmoons on wheels, radio controls,chevrolet block letters on grill, bumper pads, sliver over gold bowtie on grill & hatch, sirius, wheelskin; 13/4" Low in rear only, silverstars head & fog, now with boards, rear sway bar,
HHR B/DAY 07/04/2005
oneton is offline   Reply With Quote
Old 04-07-2010, 06:04 PM   #6
WillBeck_CobaltSS
Member #: 19842
Nope, FE5 includes the front swaybar, rear TWB, shocks/struts, springs, and control arms.
Old 04-07-2010, 09:49 PM   #7
prod
Member #: 5036
Images: 212
I believe changing to the FE5 front swaybar also requires new bushings and clamps, and dropping the front subframe to install. It may require more, as I have heard FE1 swaybar clamps are secured with a bolt on one end and a tab on the other, while the FE5 clamps are bolts on both ends. Perhaps someone could verify that.
http://www.hhrowners.spruz.com/ - Ontario HHR Owners
http://www.ontariocobaltclub.com - HHRs Welcome
prod is offline   Reply With Quote
Old 04-07-2010, 10:12 PM   #8
WillBeck_CobaltSS
Member #: 19842
some 06's and the 05's had a single bolt clamp. The extra torsion forces will eventually cause the clamp to fail. Later 06's and all following SS's had dual bolt clamps.
and yes, changing the bar requires new clamps and bushings, but it can be installed without dropping the sub-frame.
Old 04-08-2010, 06:55 AM   #9
fringeIT
Member #: 18945
Which would be easier?
09 HHR 1LT 2.2 Switchblade Silver Metallic
MagnaFlow CatBack Exhaust, Airaid CAI, Jet PowrFlo MAF Sensor, TTR Rear Sway Bar, Eibach Front Sway Bar, SS Rear Shocks and Springs
fringeIT is offline   Reply With Quote
Old 04-08-2010, 09:57 AM   #10
ZTony8
Member #: 6311
The control arms are the same part numbers on the Cobalt and the HHR so swap away!
Tony
Your friendly GM partsman-once again !
08 2LT-Cardinal red,gray cloth,2.4, 5 speed
Concieved 4/22/08,born 5-15-08,delivered 6-10-08
Sticks are cool.Clutches rule.
ZTony8 is offline   Reply With Quote
