Go Back   Chevy HHR Network > HHR SS > SS Specific Service Issues/Repairs > "Service ESC" message
Old 04-07-2010, 08:05 PM   #1
RussellM454
Member #: 6271
Coming home tonight my check engine light came on as well as the traction control light. The message center says "Service ESC" which I take to mean the Electronic Stabalization Control system. I turned off the car and it reset for a while but came back on. I have 50,380 miles on the car when this started. This is on my 08 HHR SS with 5 speed.
Anyone have any ideas what this is or what could be the cause. Also would this be a warranty type item.
Thanks,
Russ
RussellM454 is offline   Reply With Quote
Old 04-07-2010, 08:23 PM   #2
ChevyMgr
Member #: 4865
Images: 706
Could be just a bcm hiccup, but normally it would involve a power train component so the 5/100 might not pay for it. Do you have an extended warranty? They would probably cover it.
Old 04-07-2010, 08:26 PM   #3
RussellM454
Member #: 6271
No extended warranty. I thought about disconnecting the battery overnight to see if everything would reset. Or I could just come see you in the morning :-)
Russ
Old 04-07-2010, 08:27 PM   #4
ChevyMgr
Member #: 4865
Images: 706
If it comes on again send me a PM and I will hook you up.
Old 04-07-2010, 08:36 PM   #5
RussellM454
Member #: 6271
We'll see in the morning. I'll let you know.
Russ
Old 04-07-2010, 09:54 PM   #6
Mowgli
Member #: 15434
Images: 1697
Mine does that sometimes when I patch out on a cold morning.
I stopped, waited and restarted the first few times it happened.
Now I just wait until it's safe and shut off the ignition in N while still rolling.
It's cleared when I start it back up.
That way I don't have to pull over
It hasn't happened since the weather's been warmer.
I'll get it fixed along with a few other idiosyncrasies before my extended warranty's up.
2008 SS AT - bought new on 6/16/09 - 62,500 miles on 7/4/11
GMPP Stage 1 - Pioneer/XM/6 Disc - Black Cobalt SS Wheels - TTR Rear Sway Bar - Moonroof
Running Boards - Stubby Antenna/Locks - Cargo Organizer - Roof Rails - Lighter/Muffin
Mowgli is offline   Reply With Quote
Old 04-08-2010, 05:45 AM   #7
speedster
Member #: 17833
Images: 4
same thing last evening, 92 degrees on long island, parked at my sons college, started it and the same message including
"low power" "turning off traction"..it felt as if it was running on 3 cylinders. i turned it off and on again and it smoothed out..but now i have the check engine light on.. and i made my 10 mile trip home. the service dept said have it towed into my local chevy. now i have to worry about this on a trip???
wtf...
speedster is offline   Reply With Quote
Old 04-08-2010, 01:50 PM   #8
RussellM454
Member #: 6271
UPDATE:
I started up this morning the Service ESC message was on as was the check engine light and traction control light. After driving a couple blocks the Service ECS message and the traction control light turned off. At that time the traction control button was now fully functional. The car appears to be running fine but the service engine light has remained on for the 42 mile drive to work.
Russ
Old 04-09-2010, 05:47 AM   #9
speedster
Member #: 17833
Images: 4
3 codes-
P0604
P0606
PO601
power up condition, the ecm detected 3 incorrect checksums
probable cause-failed ecm
binding throttle valve
faulty tp sensor
poor electrical connection
failed tac motor
ram fault-failed ecm
ecm detected an internal performance condition- failed ecm
ecm processor error, internal fault - failed ecm
check engine light went out
dealer couldnt take the car right away, i made an appointment for sat am on line. i hope the app. held.
Old 04-09-2010, 11:56 AM   #10
speedster
Member #: 17833
Images: 4
Service appointment 10 days away "their busy"
No loaner car available, i said "wtf you told me not to use it!"
09 car with 3800 miles on it.
I was thinking on this, a weak battery on startup maybe cause this?
