Go Back   Chevy HHR Network > General Discussion > General HHR > Oil life indicator reset
Old 05-16-2010, 12:41 PM   #1
cleerdin
Member #: 17963
Could someone please tell me how to reset the oil life indicator on my 2007HHR? Thanks
cleerdin is offline   Reply With Quote
Old 05-16-2010, 01:27 PM   #2
1970judge
Member #: 3780
Turn the key to the on position and hit the gas 3 times..then crank it up and it should reset.
1970judge is offline   Reply With Quote
Old 05-16-2010, 01:29 PM   #3
gravett1
gravett1's Avatar
Member #: 4422
Images: 3
The easiest way is to turn the key to the on position & hit the gas pedal 3 times & it will clear.
Current mods: chrome antenna pedestal billet antenna chrome foglight vents shaved rear wiper, chrome tailight trim,bullet lug nuts & valve caps in-channel vent visors chrome headlight rings Drilled & Slotted rotors& ceramic pads ,tinted windows, framed billet grille, limited edition emblem,Chrome door handle cups, lower billet grille
gravett1 is online now   Reply With Quote
Old 05-16-2010, 02:34 PM   #4
ecl
Member #: 5911
Or you can turn the key to the on position and press both the info and reset button at the same time for a few seconds and then scroll through the menu till you hit the oil life reset and just hold the reset button until it says reset/acknowledged.
08 HHR LS Summit White AA5.
Black Chrome, Painted Bow Ties
http://www.cardomain.com/ride/3027190
ecl is offline   Reply With Quote
Old 05-16-2010, 08:27 PM   #5
DirtyJim
Member #: 20910
Interesting. My 2010 is quite simple...once I select the oil life by using the "info" button, I simply hold the "return" button for a few seconds until it resets. I guess this is a newer feature?
DirtyJim is offline   Reply With Quote
Old 05-16-2010, 09:01 PM   #6
bowtieboy68
Member #: 19741
Images: 89
dirty, that's how I do it in my 06
2006 LT
1995 S10
bowtieboy68 is offline   Reply With Quote
Old 05-17-2010, 10:07 AM   #7
Cajun
Member #: 6782
Images: 26
Same way in my 2008...
Life's journey is not to arrive at the grave safely
in a well preserved body...
but rather to skid in sideways, totally worn out, shouting ...
'...holy sh*t ...what a ride!'
Cajun is offline   Reply With Quote
Old 05-17-2010, 09:15 PM   #8
StaticAZ
Member #: 19929
Images: 1
The manual for my 2010 says to do do as described above with the info button but for some reason, it did not work. I read it again and it said with the 2.2 engine, you can also depress the gas pedal 3 times within 5 seconds after turning the ignition on and that did it.
StaticAZ is offline   Reply With Quote
