Go Back   Chevy HHR Network > General Discussion > Problems/Service/Repairs > Oil Leak from Somewhere
Old 05-16-2010, 09:03 PM   #1
Titans2
Member #: 1392
Got a 2006 2.0 with 71,000 miles...I just noticed a small puddle of oil on the floor - passenger side front - looked under the hood - I see stains that appear to come from under the engine mount, run down the inside plastic cover - they are also seen inside the wheel well on the lower plastic dust guard - no oil on the engine (that I can see), the oil pan is dry, the only place I see any oil is around the base of the engine mount. Had the oil changed a few weeks ago, and its very clean - this oil is very dark and dirty. Don't smell anything burning or sweet - like antifreeze.
Any suggestions as to where this is coming from?
Titans2 is offline   Reply With Quote
Old 05-16-2010, 09:08 PM   #2
steven&cat
Member #: 2127
Images: 23
You could blame B.P................
sorry ,, couldnt resist.
08 SS auto.
"The American Indians found out what happens when you don't control immigration"
steven&cat is offline   Reply With Quote
Old 05-16-2010, 11:34 PM   #3
sleeper
Member #: 2558
Images: 3
I think you may have meant 2.2, (anyway),
I'd clean all the oil stains you see, & keep an eye on those areas.
Motor oil has a detergent additive in it, it is made to get dirty quick, it's doing its job.. Even tho the dip stick oil looks clean..
Old 05-17-2010, 07:40 AM   #4
Titans2
Member #: 1392
Just talked to service - they think it may be a leaking hydraulic engine mount. Never heard of that - but it sounds reasonable.
Old 05-17-2010, 09:04 AM   #5
JoeR
JoeR's Avatar
Member #: 108
Images: 19
Not very "reasonable" since all the mounts are just rubber; no hydraulics.
Good engineering is simply finding the right wrench to pound in the correct screw.
JoeR is offline   Reply With Quote
Old 03-07-2013, 10:06 AM   #6
Dutch
Member #: 54929
I have this exact issue with my 2007 HHR LS and the funny thing is that the leak appears to originate from where the motor mount meets the frame. If there is not a hydraulic mount what else can it be? I checked everywhere around the engine and it is clean.
Dutch is offline   Reply With Quote
Old 03-07-2013, 12:30 PM   #7
SS fan
Member #: 23683
Images: 61
Welcome to the site Dutch, I took out a upper mount and they are pretty squishy, I wouldnt be surprised if there is some kind of fluid in there, but I didn't poke it to see what comes out.
SS fan is offline   Reply With Quote
Old 03-07-2013, 02:49 PM   #8
Dutch
Member #: 54929
Thanks for the response SS...I have been lurking on this site for a while now and it has been helpful with accessorizing my HHR. I was hoping that I would be joining for information unrelated to mechanical issues...ah, well.
I have been reading that chevy did produce hydraulic or fluid filled motor mounts for particular vehicles and they tended to put them more in manual transmission cars, which is what I have. I have attached a link to an old article...
http://www.motor.com/article.asp?article_ID=965
A part of that article states the following...
..."the Ecotec engine has twin balance shafts in the oil pan to reduce medium- to high-rpm shaking forces. Although these are heavier than those in the 2.2 Four, the 2006 oil pan itself is the same as the one on the earlier engine. Both bolt to the lower part of the transmission case to produce a more rigid powertrain.
The accessories are direct-mounted to reduce vibration, and there are hydraulic engine mounts designed to absorb much of whatever vibration is emitted."
Proof enough for me.
Old 03-07-2013, 09:36 PM   #9
alexrckid
Member #: 54126
hummm.....gotta do checkin under my 2006 manual shift HHR....interesting
alexrckid is offline   Reply With Quote
Old 03-07-2013, 09:43 PM   #10
Lucky
Lucky's Avatar
Member #: 5120
Images: 24
Nice info find.
Lucky is online now   Reply With Quote
