Check charging system??
Old 07-18-2010, 04:16 PM
Unhappy Check charging system??
This my second issue this week.
I pulled into my driveway and at the same time, my AC stop blowing cold, I got a "CHECK CHARGING SYSTEM" messgae in the DIC and the battery shaped icon in the gauges lit up.
When I put the car in par it idled around 2k, when I turned off the AC it dropped down to 1000 (normal for my car). When I turned the AC back on the rpms ramped up again.
Ideas?
GDZHHR is offline
Old 07-18-2010, 05:02 PM
Don06's Avatar
Serpentine belt or the tensioner break? First thing I thought of that could cause both problems. Next would be a loss of electrical power to a part of a fusebox. Since it happened as you were turning, the combination of the electric steering, AC and fans could cause an overload.
Don06 is offline
Old 07-18-2010, 06:55 PM
I just checked under the hood and you are correct, busted belt. CRAP! Not something I can do. Hopefully my neighbor hood mechanic can do it. Only a couple blocks away, if not I'll have to have it towed.
GDZHHR is offline
Old 07-18-2010, 10:31 PM
Here's the schematic for the belt set-up..
Old 07-19-2010, 01:24 AM
mikey12561's Avatar
This might be a dump question but looking at that pic brings up a question. Where the Hell is the water pump, alternator, and power steering pump. I see what looks like the compressor at the very bottom (Stupid place to put it IMO). What is above it I can't make out at all.
mikey12561 is offline
Old 07-19-2010, 06:16 AM
JoeR's Avatar
Not a "dump" question....
Water pump: Look at top left of pic. Round plate w/ 4 bolts. Water pump is behind that. It is driven by the crank on the same chain as the balance shafts.
Alternator is at the top right.
Yes, that is the A/C compressor on bottom right.
No power steering pump. The steering has an electric assist motor on the shaft. Look up under the dash and you can see it.
JoeR is offline
Old 07-19-2010, 06:29 AM
pitbull76's Avatar
While for one, there is no power steering pump. The power steering is electric instead of hydraulic like older vehicles.
pitbull76 is offline
Old 07-19-2010, 06:37 AM
Compressor on the bottom, the top looks to be the alternator. I'd guess the water pump is driver off the crank pulley?
Old 07-19-2010, 06:48 AM
I believe you are correct on that......
Greybeard999 is offline
Old 07-19-2010, 10:13 AM
My turbo set-up complicates things some and I just don't have the ability to get the car high enough for my fat butt to get underneath with enough clearance to do this easily. I've got jackstands but this is still beyond what I can do in my driveway. Taking in to my local guy in the morning.
GDZHHR is offline
Quick Reply: Check charging system??
