Replacing the Serpentine Belt
Old 08-25-2010, 02:50 PM
hhrEH's Avatar
Question Replacing the Serpentine Belt
Hey fellow HHR owners
First post here ever...
I have to replace my serpentine belt and noticed last night that there isn't a whole lot of room in there to move around. I thought I might limit my frustration a bit and ask the experts first. Any tips or tricks or secret passageways?? My dealer wanted $130.00 to do the job, thought it was kinda high as I used to do this work on my old little jimmy all the time.
Thanks from Canada
no canadian jokes eh!
hhrEH is offline
Old 08-25-2010, 04:33 PM
Welcome.... Not sure where the experts are at the moment, but here goes..
Perhaps the illustration will help, Yes it is tight conditions.
I would start at the crank pulley & then go over the A/C pulley, pull back the tensioner, & loop it over Alternator & gently release the belt tensioner..
IIRC a 3/8" drive rachet will fit the tensioner square hole (see pic) to pull up on it.
Old 08-25-2010, 04:47 PM
hhrEH's Avatar
Thanks Sleeper
That is kinda what I thought too, now I just have to make my arms a little thinner and I think I'll be able to do it!
HHReh
hhrEH is offline
Old 08-25-2010, 05:08 PM
Need to remove the passenger side access panel under the vehicle and come in from the bottom.
Old 08-25-2010, 05:18 PM
hhrEH's Avatar
Thanks ChevyMgr
See I knew there was a secret hole!
hhrEH is offline
Old 08-25-2010, 05:46 PM
Not sure where you are going to do this, but a lift makes this an easy job. On your back won't be so easy.
Old 08-25-2010, 11:03 PM
IgottaWoody's Avatar
After you remove excess amounts of accumulated snow....oh sorry , you said no jokes.........
IgottaWoody is offline
Old 08-26-2010, 04:20 AM
mrsilent13's Avatar
easiest way of doing it is with 2 people....one pushes up on tensioner while other slides belt off the alternator....and then to put it back on...go from the bottom up....crank, a/c, tensioner...then push up on tensioner and have second person loop onto the alternator...no more than 2 minutes to remove and reinstall
mrsilent13 is offline
Old 08-26-2010, 08:06 PM
skyeglen's Avatar
mrsilent13 is spot on with his suggestions. Did mine exactly that way @ 75K miles and it literally was no more than 2 minutes.
Wheel was off for another reason so that made it easier but we didn't remove any panels.
skyeglen is offline
Old 02-22-2011, 12:39 AM
rcdougie's Avatar
Is the proper way to relieve tension by using the 3/8 square hole in the tensioner or the 15mm bolt that holds the tensioner on?
rcdougie is offline
Quick Reply: Replacing the Serpentine Belt
