Go Back   Chevy HHR Network > General Discussion > Problems/Service/Repairs > Door lock stems not always going fully up/down
Old 09-07-2010, 09:50 AM   #1
jerSSey HHR
Member #: 7605
Recently some of my door lock stems don't seem to be going all the way up or down when I lock or unlock the car. Yesterday I saw my driver's side door lock stem sticking up so I assumed the car was unlocked. So I opened the door and the alarm went off, indicating that I had locked it remotely but the lock stem didn't go all the way down. So far it has been happening with the driver's door and the passenger side rear door locks that are having this problem.
Has anyone else had this issue? I'm way past warranty so I need to try and fix this myself. It's almost as if the servo motors are too weak to push or pull the stems. Unless there is something in the door that is binding them from moving. I was going to try lubrication next, but I don't want to have to open up the door unless I absolutely have to.
2008 HHR SS - (105K miles)
2004 Grand Prix GT (137K miles - SOLD)
2002 Avalanche Z71 (109K miles)
Racking up the miles in my GM's!
jerSSey HHR is offline   Reply With Quote
Old 09-07-2010, 09:56 AM   #2
diskullman
Member #: 5298
Images: 29
I had this issue, but the battery on my remote was dead, the knob was in the halfway position, and the key wouldn't budge it. This is when I discovered there is only 1 door with a key latch, and I had to call in the road service folks to open the door, which GM covered ( they could hav just popped the lock with Onstar, but I did not subscribe.)
<img src=http://www.chevyhhr.net/forums/images/smilies/bow.gif border=0 alt= title=Bow class=inlineimg /><img src=http://www.chevyhhr.net/forums/images/smilies/bow.gif border=0 alt= title=Bow class=inlineimg /><img src=http://www.chevyhhr.net/forums/images/smilies/bow.gif border=0 alt= title=Bow class=inlineimg /><img src=http://www.chevyhhr.net/forums/images/smilies/bow.gif border=0 alt= title=Bow class=inlineimg />
diskullman is offline   Reply With Quote
Old 09-07-2010, 10:13 AM   #3
Greybeard999
Member #: 19723
Images: 120
I thought ChevyMgr posted something about this issue not too long ago, not sure if it was a TSB or what..... there is some foam down in the shaft area that is causing this if I remeber correctly.
http://chevyhhr.net/forums/showpost....&postcount=150
See if that's the issue.
____ ***** October 2010 featured HHR ***** ____
>> 2.4L, GMPP, Trifecta, Ground Force/Progress suspension <<
Greybeard999 is offline   Reply With Quote
Old 09-07-2010, 11:12 AM   #4
ecl
Member #: 5911
Have this problem with my rear passenger door as well. It happens when I try to unlock it only no problem when locking. Suck when I go to unlock it either with the remote of the button on the door I have to unlock the doors twice to get that door unlocked. I to am out of warranty so if you find a fix let me know.
08 HHR LS Summit White AA5.
Black Chrome, Painted Bow Ties
http://www.cardomain.com/ride/3027190
ecl is offline   Reply With Quote
Old 09-07-2010, 11:54 AM   #5
jerSSey HHR
Member #: 7605
I'm thinking of squirting a tiny bit of WD-40 or white lithium grease into the lock opening.
Old 09-07-2010, 12:09 PM   #6
Mrs. DLVRNIT
Mrs. DLVRNIT's Avatar
Member #: 15263
We're pretty sure this has been discussed on other threads! Our driver side door did the same thing! We removed the knob and lifted the panel just past the rod. We then took a rat tail file and carefully reamed out the hole! Popped the cover back on and re-installed the knob No issues since!
Best-O-Luck ,
BONNIE and KEVIN DRAKE / DLVRNIT / 2008 1LT PANEL
18" SS COBALT WHEELS / SS FRONT & REAR PERFORMANCE SEATS / SS 140 MPH SPEEDO / SS STRUTS and SHOCKS / SS REAR SPOILER / SS STEERING WHEEL / TCE-WILWOOD BIG BRAKE KIT / EIBACH PRO SPRINGS / EIBACH FRONT SWAY BAR / OTT HARDCORE REAR SWAY BAR / CERAMIC COATED EXHAUST / GMPP EXHAUST MANIFOLD / MAGNAFLOW STAINLESS EXHAUST / HIGH FLOW CAT DOWN PIPE / TRIFECTA TUNE / JET PERFORMANCE MAS / POWDER COATED VALVE COVER & CGS CAI / 3 BAR GRILL.....
Mrs. DLVRNIT is offline   Reply With Quote
Old 09-08-2010, 12:25 AM   #7
prod
Member #: 5036
Images: 212
It could be either the interior panel interference or a malfunctioning lock mechanism, mine had both. I think the best way to test it is to remove the interior door panel and try to operate the locks. If it still doesnt work right, then the locking mechanism might need to be replaced.
http://www.hhrowners.spruz.com/ - Ontario HHR Owners
http://www.ontariocobaltclub.com - HHRs Welcome
prod is offline   Reply With Quote
Old 09-08-2010, 12:58 AM   #8
sleeper
Member #: 2558
Images: 3
Or just remove the chrome plastic knob & test it..
Old 09-08-2010, 03:19 PM   #9
jerSSey HHR
Member #: 7605
Do the knobs screw off?
I'm wondering why this would start happening after 43K miles on the vehicle? How could the interior panel just start interfering? Could it have shifted over time? Warped?
Old 09-08-2010, 03:38 PM   #10
Mrs. DLVRNIT
Member #: 15263
Ours started at about 25,000 miles! Do what "SLEEPER" said though and just un-screw the knob and test ! If still stuck it's a mechanism issue !
(P.S. We used a rat tail file and just kinda gently screwed it into the hole "easily" to open it up slightly)!
Best-O-Luck ,
